coupe Offline
#1 Posted : Thursday, 20 August 2015 4:37:50 AM(UTC)
coupe
Hi im looking for the part numbers for both front and rear unis for a hk with a v8 powerglide and 10 bolt diff all factory. Tailshaft length is 1364 from memory if that makes a difference. Just out of curiosity is the tailshaft the same as a saginaw?
gm5735 Offline
#2 Posted : Thursday, 20 August 2015 5:36:14 AM(UTC)
gm5735
The front is VS10606.
The rear is VS10798.
The shaft is the same Dark Green shaft as the 307 and the 327 Saginaw/M21 cars.
coupe Offline
#3 Posted : Thursday, 20 August 2015 5:43:22 AM(UTC)
coupe
Mine is light purple and is suppose to be from a 327 hk gts. Thanks for all the info!
gm5735 Offline
#4 Posted : Thursday, 20 August 2015 6:01:33 AM(UTC)
gm5735
It probably is. The HT350 manual used the violet shaft initially as well.
The original HK327 Dark Green shaft was 2.75", and replaced with the 3" Violet shaft as part of a recall.
Just to prove they still couldn't get it right, I believe the HT350 manual Violet shaft was replaced with an orange shaft as a recall.
coupe Offline
#5 Posted : Thursday, 20 August 2015 6:28:36 AM(UTC)
coupe
Yes mine is the 3 inch shaft. You wouldnt have the colour code for the violet would you or know where i can get it?
