#1 Posted : Sunday, 29 May 2005 2:58:28 AM(UTC)
G,Day every one, will the cast or alloy crossflow cylinder heads bolt onto these old blocks? What has to be done to achieve this conversion? any interesting challenges to this mod? Regards, Pete.
#2 Posted : Sunday, 29 May 2005 7:53:13 PM(UTC)
no a x-flow head will not fit,don't matter whether it alloy or cast iron as a x-flow block is around half an inch wider than the pre x-flow.but all is not lost a 250 2v head will bolt straight to any 170,221 etc etc and there an exellent head.
#3 Posted : Monday, 30 May 2005 1:02:21 AM(UTC)
#4 Posted : Tuesday, 31 May 2005 8:14:18 PM(UTC)
You may get away with throwing the 221internals into the crossflow block.
Thus getting yourself a higher revving alloy head engine.
#5 Posted : Wednesday, 1 June 2005 8:19:22 AM(UTC)
Thus getting yo
#6 Posted : Wednesday, 1 June 2005 6:47:16 PM(UTC)
the best way to go is to use 200 rods in a 250 and the acl piston kit to suit 200 rods in the 250 motor.this makes them rev to 6-7 grand and strokes the engine.turns them into a real quick engine.
#7 Posted : Thursday, 2 June 2005 7:04:46 AM(UTC)
#8 Posted : Thursday, 2 June 2005 6:24:03 PM(UTC)
were i live there is a cult following for cortina's at the speedway and forget the 202 mate these cortina's are giving them a real flogging.not sure about the ci of the engine after the 200 rods etc have been done but alot of speedway people use this comb
#9 Posted : Thursday, 2 June 2005 9:35:38 PM(UTC)
[/quote]by utalising this option, does the cubic capacity alter or does it remain 250ci?. class limit is 250 ci max. cast iron head, must use 500 holley 2 barrel. however less than 250 ci can use triple SU's.
[/quote]
Putting the longer 3.3 rods i
#10 Posted : Friday, 24 June 2005 11:10:48 AM(UTC)
Mate, stick with the log. But, Get your hands on a "2V". Had one in an XY. Usual stuff for the bottom end, Good parts, Balance etc..bout 10-1 comp.Big solid camshaft,Good ignition, tunned pipes and a 465 4 barrel holly.The only mod to the head was larger
