#1 Posted : Friday, 3 June 2005 7:34:10 AM(UTC)
Hi guys.......Only new to this site and i thought i would test the water in regards to a problem i may have (or not) with my Commodore.
The car makes a noise at the front end when just after starting ,once moving off you hear a scrapping sounds coming from the front end... (only ever so slightly)
Now this only happens once after starting and i was informed that it will be the ABS doing a self check..........
Can anyone tell me if its a normal thing or not???????
Thanks Guys and Girls for reading
Rusty
#2 Posted : Friday, 3 June 2005 8:13:07 AM(UTC)
Hi Rusty, if no-one on here knows the answer, I know this has been discussed at length on www.ls1.com.au
Cheers...Dave
#3 Posted : Saturday, 4 June 2005 7:11:40 AM(UTC)
Thanks very much for ya time.......Will check it out
#4 Posted : Friday, 1 July 2005 4:29:58 AM(UTC)
It is definitely normal for this to happen. It is an ABS self test. If it is too loud, then there is a modification that can be carried out at your local Holden Dealership. Under Warranty of course.
