#1 Posted : Sunday, 5 June 2005 3:14:47 AM(UTC)
any ideas where one can get piccies of the inside of the engine which show filter and oil release plug at the bottom of the engine. similar to a haines book in detail?
#2 Posted : Monday, 6 June 2005 4:34:08 AM(UTC)
for the sump plug you need a t45 torx bit and it under the motor and the oil filter is locate on the front of the engine under the exhuast manifold. it will be either a spin or oil filter or a cartridge one the do these with a 3/8 ratchet. unless its turb
Tour Director Offline
#3 Posted : Tuesday, 7 June 2005 4:57:52 AM(UTC)
Tour Director
Your Holden dealer should be able to help with a printout of the filter location from their " Microcat" system.Up to engine 20V0064 the filters were a cartridge type. 20V0065 they became a screw on type.Unfortunately their parts catalogues are only availa
This page was generated in 0.131 seconds.
