iitsmint Offline
#1 Posted : Tuesday, 10 April 2007 9:18:01 AM(UTC)
iitsmint
Current project underway is a hq ls coupe factory 350, one of 216 of these cars built by holden
Its a matching numbers car and was ontained from FNQ thanks to my mate in melbourne and his father who was travelling in QLD at the time. I had been searching for a project for a while and I was lucky enough to stumble across this one " with a little help from my friend"
Its a 350 factory hq ls, with a prototype sliding sunroof, 3.36 lsd and turbo 400, I told quite a rare car, its got factory power windows, aircond and power steer. As I said its a rebuild project
First job was to get the engine to run, it had been filled with oil and in storage for 8 years, I got it running after a while, what a bloody racket, I pulled the timing case cover off to reveal a gear drive! next i removed all hang on panels and ripped out the eng and trans, next was to strip the shell and have it sand blasted, gees the blasting has revealled quitre a few previuos repairs as well as blowing some holes in the floor and boot. A donner car was sought for a complete front floor pan and pillar sections. A road trip from PERTH TO KALGOORLIE uncovered a nosw rh outer, a repairable rh door and a set of gts gaurds. This car is going to be rebuilt to orginal except for the gaurds. I have been told by the previuos owner that this car was built and used as part of holdens road show of the time, hence its optioned up with a gts dash as well. Anyway the photos are on the following link. Im chasing some parts if anyone can help, rear window mouldings, rear seat frames cause mine are very rusty!
http://s178.photobucket.com/albums/w275/itsmint/
iitsmint Offline
#2 Posted : Tuesday, 10 April 2007 9:20:50 AM(UTC)
iitsmint
also looking for a good boot floor to weld in if anyonw has one of even parts of. ta o411332664
#3 Posted : Friday, 27 April 2007 11:40:50 PM(UTC)
when you say ,FNQ, what part of queensland are talking about? did this car have a cream interiour? thx
#4 Posted : Sunday, 29 April 2007 2:27:14 AM(UTC)
Why do you ask?? Did you see it somewhere?
#5 Posted : Monday, 30 April 2007 12:42:48 AM(UTC)
yeah it looks like a car that used to be owned by a guy in rockhampton in the early eighties,if its the same car then its a bloody beautyful vehicle.
Rock_Lobster Offline
#6 Posted : Monday, 30 April 2007 8:23:59 AM(UTC)
Rock_Lobster
There was a beautiful one in Korumburra years ago.
Then some D***head grafted a ute back onto it.
Nearly made me cry.
#7 Posted : Tuesday, 1 May 2007 6:52:10 PM(UTC)
yeah,i remember seeing a story about it in one of the magazines,what a waste.
#8 Posted : Thursday, 3 May 2007 7:35:25 AM(UTC)
Yep the car came from the rocky area, in need of alot of work though!. I would say it underwent a 80s rebuild, had a half roll cage put in at the same time, and had some rust repairs. The body has seen better days, but I reakon I can bring it back. Proven to be a lot of work so far, with a great deal more ahead.
ps looking for rear window chrome 0411332664 ta
#9 Posted : Monday, 19 November 2007 11:08:50 PM(UTC)
Try rare spares or wreckers
#10 Posted : Thursday, 27 December 2007 10:39:22 AM(UTC)
Udate to the project p have got a rear window set of chrome from a melb wrecker at a very reasonable price, also imported a good secondhand scuttle panel that a mate cut out of one of his hq sedan wrecks. secured a good boot floor from a very helpful chap in balga, and a very good beaver tail panel from another sedan. All sill replacements completed, front floor sections replaced from donner sedan, rear floor pans under back seat replaced from same donner, parcel shelf roll bar holes repaired, rear sub frame chassis section replaced.
Next jobs, remove rusted boot floor and fit donner floor, remove scuttle panel and replace with donner, replace rear beaver tail panel(big job!!!!!!!! but due to a previous arse end hit, needs to be done as the existing one is half porcelain) will post some more photos soon on link. Like to mention have had a lot of good advice and help from the guys here in wa doing coupe rebuilds now or in the past with info and contacts
#11 Posted : Thursday, 24 January 2008 5:27:23 AM(UTC)
Have done the foloowing work and uploaded more photos for those interested, replace lh sill replaced rh sill, replaced boot floor, replaced part of back floor under rear seat, replaced strenghtining member between rear quarters inside cabin, repaired seat belt anchor points, Im happy to share the experience if you have any questions, (i might add, not bad for a security gaurd who knows nothin about cars, HEY EXPERIENCED FITTER!!!!!!!!!!!!)
#12 Posted : Thursday, 24 January 2008 6:13:27 AM(UTC)
#13 Posted : Saturday, 12 April 2008 8:10:31 PM(UTC)
Update for thoses that are interested. All floors now complete, inside painted with body deadner and two pack black paint. I decided to go this way to protect the floors from rusting in the future and to minimize road noise. Under the car the floor pans are painted 2 pack black and look really smick. Both sill panels are completed. Rear panel was cut out and replaced due to being full of bog, unfortunately I was unable to pick up on the production joints on the rear quarters and had to join quarter panels anout an inch higher. The car had previously sustained a hard hit up the back and a lot of filler was used. Looks pretty good now though. The rear cut was obtained from a wreckers in Malaga for $300 that hurt a bit considering in the past Ive had several q sedans i sent to scrap with good panel parts!
Next Roof gutters are very rusted with some less than good repairs. Ive unpicked a sedan roof along the joins to the gutter, and whilst the profile isnt the same towards the back of the coupe roof, Im going to cut, shrink and roll it to get the profile. Im using the coupe gutter moulding as a template. Anyone else done this before pls let me know what you did. After the roof gutters are complete, it will be time for the scuttle and plenum chambers to be replaced. Then the sunroof repair, its got a protype sliding panel sunroof fitted and is believed to be an orginal fittment during the build of the car. The reason I reakon its a prototype hj sunroof is because its slightly different from that of the hj series sunroof. This car was build for the gmh release show circuit apparently so I was told from the guy I bought it from, which would be consistant with the sunroof fitment and that its actually different from the hjs If anyone has a q stato or other with a sliding panel sunroof I would be interested to look at it via photos or in person if possible. Manily beacuse I have to manufacture the parts to repair mine, and some parts are just flogged out too much. [email protected] some new photos added see link below
#14 Posted : Friday, 6 June 2008 8:48:58 AM(UTC)
more photos uploaded mega stress roof repairs and pleumn. scuttle panel fitment.
nearing time to meet the panel beater!
#15 Posted : Sunday, 14 September 2008 10:15:17 AM(UTC)
Roof repairs and scuttle repairs complete. Thanks Rockett for the scuttle, it fit a treat
Guest (13)
