#1 Posted : Tuesday, 16 November 2004 3:53:41 AM(UTC)
Hi all, I've got a XE alloy head 250 x-flo and have just instaled a 350 holley on it ( wish someone warned me bout clearin the intake manifold bolts with the adaptor plate, lol). It has a flat spot just as I put the boot into it. It's ok just cruising and once past the initial flat spot gets up and goes. What jet size is good for a 250, the 350 came off a 253 h****n V8 so I thought it might b ok. Could it mean I need to run a re-build kit through it cause it could be the pump inside? Also while I'm posting, anyone live in tassie have a cheap 250 short motor for sale?
THANKS HEAPS
#2 Posted : Tuesday, 16 November 2004 4:01:50 AM(UTC)
hi I once owned a xe van . I had better luck mucking around with the jets in the webber. sorry I'm not a fan of holleys. and when it come rego time they just see a standard carby with the so called pollution gear no worries they dont need to know whats in
#3 Posted : Tuesday, 16 November 2004 5:14:33 AM(UTC)
Yeah true but the holley flows more, and with the addition of the adaptor plate, which ended up being abot 1 1/2 inches thick, to increase plenum volume, the power comes on a bit higher and lasts longer. Also I'm now doing about 250RPM less down the highw
#4 Posted : Tuesday, 16 November 2004 5:26:46 AM(UTC)
Change the accel pump as thats what it sounds like.
#5 Posted : Wednesday, 17 November 2004 7:34:01 AM(UTC)
Thanks for the advice Brenden, I've priced a complete re-build kit at my local parts bloke for $45 (or a $125 at Repco for the same kit!!!). Will this include what I need to repair the accel pump, thats what I thought it was although I didn't know what th
#6 Posted : Wednesday, 17 November 2004 7:38:38 AM(UTC)
I've also priced a set of mains and big ends, sump gasket and front and rear crank seals for $150. Should fix my low oil pressure at idol, or is there a common problem with oil pumps in 250 X-flows?
#7 Posted : Sunday, 5 December 2004 1:46:00 AM(UTC)
all engines have low oil pressure at idle it is not going to hurt it at all, if your worried about it put some moories addetive or some like that, i'll tell u why.
Catipiller assembled an engine and all they did was put moories on the bearings and pumped
#8 Posted : Sunday, 5 December 2004 1:46:23 AM(UTC)
#9 Posted : Friday, 31 December 2004 1:55:02 AM(UTC)
Well, a couple of things. If the flat sport is just after you "put the boot in" then the accelerator pump is fine. Don't worry about jets either. You probably have very good vaccuum and the power valve is not opening early enough!
Most Holley c
This page was generated in 0.112 seconds.
