2 Pages<12
peter_flane Offline
#21 Posted : Thursday, 23 December 2010 7:21:28 AM(UTC)
peter_flane
You can use blank HQ-WB discs and get them studded to LH-UC stud pattern. The EH guys do it quite often. You have to run 14" wheels
bullitljv8 Offline
#22 Posted : Thursday, 23 December 2010 8:51:56 AM(UTC)
bullitljv8
can you buy blank lx discs and get them redrilled to suit hq??? as putting hq stubs throws the lx steering out the bump stop especially unless you buy the a9x steering arms so im told i did a friends lx torana once with hq stubs we used uc steering arms it wasnt to bad but still had trouble with bump stop
Edited by user Thursday, 23 December 2010 8:56:59 AM(UTC)  | Reason: Not specified
peter_flane Offline
#23 Posted : Thursday, 23 December 2010 9:28:59 AM(UTC)
peter_flane
I can't see why you could not get HQ stud pattern on an LX disc unless the size of the surface area is not available to do it. I will ask. Were there A9X Torana's with HQ stud pattern?
#24 Posted : Thursday, 23 December 2010 5:27:26 PM(UTC)
I reckon that whole bump steer thing is a bit of a gee up by the Torana nuts. I had an LX hatch that I put a UC crossmember in with HZ stubs, discs and calipers with UC steering arms. It was the best driving and handling car I ever owned. The A9X/L34 steering arms are now reproduced by Harrop.
Peter, all L34 and A9X ran HQ-WB discs. L34 ran HK-early HX stubs, A9X ran late HX to WB stubs.
martycassie Offline
#25 Posted : Tuesday, 28 December 2010 6:20:49 PM(UTC)
martycassie
G,day all, re the WB Tonner with the HZ Statey disc rear end. I,Ve decided to put 1.5" lowering blocks in to clear the hanbrake levers on the calipers. But I need all the cables & the small levers that operate the handbrakes at the calipers, Any body got some?? Cheers, Marty 0408575903
stephenreed Offline
#26 Posted : Saturday, 23 July 2011 2:41:19 AM(UTC)
stephenreed
I have just put a disc brake set-up on my HQ Tonner.
Can someone tell me what is the name of the valve you need to remove to make them work properly and is this valve in the master cyclinder?
1970 HG Panelvan
1971 HQ 1 Tonner
2001 WH Statesman
Kawazaki KLX250SF
chrome yella Offline
#27 Posted : Sunday, 24 July 2011 12:25:05 AM(UTC)
chrome yella
L34 ran HQ stubs with cast iron prb discs,hq patten
A9X had alloy girlock disc, Hq patten
#28 Posted : Sunday, 24 July 2011 2:05:14 AM(UTC)
It's called a residual pressure valve & it consists of a small spring & rubber piece which is held in place by the outlet fitting olive. Simply remove the olive, discard the spring & rubber & refit the olive.
4 wheel drum cars have two of these, front disc cars got one & 4 wheel disc cars have none.
stephenreed Offline
#29 Posted : Monday, 25 July 2011 7:44:33 PM(UTC)
stephenreed
Thanks Dr..
Just to confirm it is in the Master Cyclinder the end closet to the brake booster?
1970 HG Panelvan
1971 HQ 1 Tonner
2001 WH Statesman
Kawazaki KLX250SF
stephenreed Offline
#30 Posted : Thursday, 4 August 2011 1:23:27 AM(UTC)
stephenreed
Thanks for the help guys, managed to find it and remove it. Nearly got the one tonner back on the road, woooo.
1970 HG Panelvan
1971 HQ 1 Tonner
2001 WH Statesman
Kawazaki KLX250SF
Guest (6)
2 Pages<12
