#1 Posted : Wednesday, 22 June 2005 6:20:32 AM(UTC)
Ok i bought a disk diff the other day it came with the booster and master cyl, the guy i bought it off said it came off a hz statesman and i was wondering if theres any way to check as one of my mates said they only had 10 bolt sailsburys where as this is a 2.78 12 bolt the booster is a pbr type as is the master cyl the booster is quiet deep where as the previous drum type off my current holden is rather widered like a frypan is easyiest way to describe it
Any help would be appreicated
Glenn
#2 Posted : Wednesday, 22 June 2005 6:09:02 PM(UTC)
The HZ disc brake booster is a lot smaller in 'diameter' than the drum brake one. How do you know you have a 12 bolt? There has never been a 12 bolt 2.78 diff fitted to a Holden. The lowest ratio was 3.55 or 3.73 I think, and these were only in HK/T/G 818
#3 Posted : Thursday, 23 June 2005 7:37:16 AM(UTC)
ahh well i was told it was a 12 bolt by the bolts holding the rear cover on but if it go's by what you say then it is infact a 10bolt and is definatly a 2.78 as thats what is stamped on the diff body itself as well as the crown wheel
#4 Posted : Thursday, 23 June 2005 8:48:42 AM(UTC)
Hi Guys.
To my knowledge the 2.78 ratio was superceded by the 2.60 ratio in late 1975, well before the intro of the HZ rear disc set-up.
You can swap all the disc brake stuff (including axles) to any large 10-bolt Holden Salisbury diff. This may be
#5 Posted : Saturday, 25 June 2005 6:22:59 AM(UTC)
Well after further inspection i believe you maybe right its definatly a 10bolt with a 2.78 center but the rear sway bar mounts i just noticed when i started cleaning it had car bog on them hit it with wire wheel and yep some ****ty arsed welding covered u
Taz2 Offline
#6 Posted : Saturday, 25 June 2005 3:47:01 PM(UTC)
Taz2
We had this problem at work.
A guy in Hobart wanted a 12 bolt Salisbury for his Torana.
We told him that Salisburys were 10 bolt unless he wanted early Chev, and they were pretty scarce and probably wouldn't fit his Torana without modification anyway.
In thrust we trust
#7 Posted : Sunday, 26 June 2005 6:14:27 AM(UTC)
Sigh this has to be the diff from hell, i finished wire burshing the diff back and gave it a blast with metho to clean all dsust and such off and out of it when i looked inside the diff arm (where the axel go's along) and i noticed a what looked like a bu
