#1 Posted : Wednesday, 22 June 2005 9:37:04 AM(UTC)
I've almost convinced myself to drop the rails out the HQ, to do a better job of the rust repairs, repaint etc. I've taken the front clip off a few Q's & J's but never the rails. Anyone got any tips or advice to make the job easier? Was thinking of leaving the motor in the rails, then lifting the motor of the rails. Any thoughts?
Thanx Webby
#2 Posted : Wednesday, 22 June 2005 10:49:53 AM(UTC)
just finished doing it to my hj caprice i had motor off to do it, i was then able to just use myself and 2 mates to lift it off and put it back on again after the repairs were done i had 4 car stands 2 at rear of car and then i placed a peice of wood acro
Taz2 Offline
#3 Posted : Wednesday, 22 June 2005 3:42:15 PM(UTC)
Taz2
I've done this countless times....both with the engine in, and also out.
Basically set the stands up as GlenPerth has suggested, with the front wheels off the ground by about 2" at least.
Put a jack under the front engine crossmember.
Take out bolts 1/
In thrust we trust
#4 Posted : Thursday, 23 June 2005 2:05:17 AM(UTC)
Taz, how have you gone with re-aligning the chassis back to the body?? any tip's on this will be very helpful as i have to replace the rails on my brothers HJ wagon soon..
thank's in advance Kevin
#5 Posted : Thursday, 23 June 2005 6:43:51 AM(UTC)
I replaced a bent front end/rails complete on a Q wagon on my own it was basically unbolt the chassis bolts disconnect the brake lines and remove the gearbox support jack the motor up I supported it with a timber across the guards wheel the old one out th
#6 Posted : Thursday, 23 June 2005 8:00:59 AM(UTC)
Just use a piece of string & make sure your diagonals are equal.
Taz2 Offline
#7 Posted : Thursday, 23 June 2005 4:04:04 PM(UTC)
Taz2
The subframe is a very snug fit, and sits against the rocker panels/sills neatly.
I'd suggest that the frame will go in aligned correctly by itself provided your body/subframe is straight originally. (see JohnPerth above).
If you have any doubts, use a
In thrust we trust
#8 Posted : Thursday, 23 June 2005 7:09:26 PM(UTC)
Thank's john, commodorenut & Taz...
Kevin
#9 Posted : Saturday, 25 June 2005 7:11:05 AM(UTC)
Thanks for the advice. It confirms my own (sometimes ratbag, but not in this case) theories.
Webby
#10 Posted : Thursday, 14 July 2005 9:58:47 AM(UTC)
Hey Man,
Whats these rails you going on about do you mean the chassis if so its real easy dude, just undo all the bolts holding the body to the chassis disconnect the fuel hose and the fuel filler pipe, disconnect the electrics, disconnect the steering,
