#1 Posted : Thursday, 23 June 2005 7:28:40 PM(UTC)
HI guys,just what is the difference from a HZ V8 front end to a 6cyl front end other than the springs. Im doing up a ute and wrecking a 6cyl ute for someparts i need. On the 6cyl ute all the control arms are painted new bushes,same with the back end. Painted leaf springs and shakles and rebushed. but its still the banjo. i want to move everything over to my ute as mine is a factory V8. 4sp 10bolt. thanks for you time.... David
#2 Posted : Thursday, 23 June 2005 7:44:19 PM(UTC)
AFAIK if they're both the same model year (ie. rts/non rts), also the sway bar.
#3 Posted : Thursday, 23 June 2005 10:11:29 PM(UTC)
All the same except possibly front coils, but you're better off with STD height aftermarket coils anyway as they're heaps easier to fit than originals. Check the steering arm lengths whilst doing the swap as plenty of stuff gets swapped around over 25 yea
Jim Briar Hill Offline
#4 Posted : Friday, 24 June 2005 2:45:36 AM(UTC)
Jim Briar Hill
All the same part from the springs. When you do the work keep any old shimms as I found the other day that my local wheel aligning bloke will only do the job if you pre book as he orders the shimms in for the job ( guess you cant get the multi packs anymo
Edited by user Friday, 24 June 2005 2:47:05 AM(UTC)  | Reason: Not specified
mackv8 Offline
#5 Posted : Friday, 24 June 2005 5:31:53 AM(UTC)
mackv8
there are 3 types of factory front springs in the hz ute/van.6 cyl standard pn 2825748.6 cyl with air (c60). out back pack no air (xw5) pn 2825749. 6 cyl (xw5)with air (fe7) and all v8 2825750. hope this helps
looking for an ex ambulance based on the hj/x/z 2 tonner see photo
and collector of all things ambulance police fire and the odd hq to wb parts
#6 Posted : Friday, 24 June 2005 8:25:05 AM(UTC)
the v8 ute I wrecked had much thicker sway bar, I would think with the extra weight that would be standard.
#7 Posted : Saturday, 25 June 2005 7:23:34 AM(UTC)
Do they charge you for shims ? ( the money I've thrown away during my wheel alignment years!!!!) Just as well I've got big shim stacks in the Q ( love that positive castor) could be a gold mine.
Webby
#8 Posted : Saturday, 25 June 2005 9:03:40 AM(UTC)
Thank you for all the feedback guys. it has really helped me .......David
