#1 Posted : Tuesday, 11 March 2008 1:56:08 AM(UTC)
Having some trouble with my commodores central locking. Both my remotes stopped working and both keys only unlock my drivers side door only, all other doors remain locked. When u push the lock up it springs back down. After looking in the owners manual i read that i have to turn the switch which i cant remember what its called, sorry, anticlockwise which is located near the door hinge on the passenger side door. Problem is as stated before the lock springs back down, the door remains locked and im unable to open the door. Even if i hold the lock up the door still wont unlock and open. Ive disconnected the battery and tried to do it like this it worked the first time and ive done it exactly the same this second time but it fails to work. Any help would be greatly appreciated.
#2 Posted : Tuesday, 14 October 2008 11:33:31 AM(UTC)
Sounds like the central locking sencor
#3 Posted : Tuesday, 14 October 2008 4:18:27 PM(UTC)
Sounds like its still deadlocked.
Check the passenger side door lock isnt locked in the deadlock (horizontal) position.
If its not, then its time to take off the door trim (drivers) and check the deadlock switch thats fitted to the side of the key barrel in the drivers door handle.
#4 Posted : Wednesday, 10 December 2008 12:08:27 AM(UTC)
I recently removed the Stock Stereo from my VR Equipe the other day and then connected it back together.. Now for some reason the stereo wont work, Neither will the electric windows or central locking.. Help me!
rotagem74 Offline
#5 Posted : Wednesday, 1 April 2009 6:19:07 AM(UTC)
rotagem74
hi my vr calias wont start key pad wont lock doors an wont make lights flash. when i put key in to start reds are on but nothing no noise i notice that the security light on dash dosnt flash to.pls help i need my car. cheers
dakotakdq Offline
#6 Posted : Wednesday, 1 April 2009 7:54:42 AM(UTC)
dakotakdq
rotagem74 -
if you try and start car and red light ISNT flashing, no doubt you need a new BCM (or maybe just a key), if red light flashes youll just need new remote key :)
Try this simple test, put key in ignition, turn to on position, leave for anywhere from 20mins to 4hrs and try and start car (if red light is flashing car wont start). This will bypass the imoblizer so you can take it to a Holden dealer and get it repaired :)
Once the buttons break on commodore keys its time to gte them replaced, if any dirt, dust etc gets in them you wont be able to lock or unlock your car!
Edited by user Wednesday, 1 April 2009 7:57:45 AM(UTC)  | Reason: Not specified
Dylza Offline
#7 Posted : Wednesday, 24 February 2010 9:27:21 AM(UTC)
Dylza
hey i have a vr commodore my central locking was working then just stoped the lights flash when i push the button but the doors dont lock or unlock does any one have any ideas???? thanks
