clyde60 Offline
#1 Posted : Tuesday, 15 April 2008 12:25:03 AM(UTC)
clyde60
I want to replace my old rear seatbelts with inertia type, could you please tell me what model no. I need to order. There are so many of them listed it is confusing.
les Offline
#2 Posted : Tuesday, 15 April 2008 1:43:16 AM(UTC)
les
clyde60
I do not have the facilities to answer your question ,I will get someone from one of the shops to advise you
Les
Duzty Offline
#3 Posted : Tuesday, 15 April 2008 2:54:11 AM(UTC)
Duzty
we need to know the bolt size of bolts holding in your current belts, it will either be a 7/16" or 1/2" size bolt. also need to know if it is a wagon or a sedan.
Rare Spares Perth (REX SPARES) Representative. If you have an enquiry, feel free to message me. To shop online directly from Rare Spares Perth go to https://rsp-secure.com/r...pares/?referrer=fastlane
Edited by user Tuesday, 15 April 2008 8:44:42 PM(UTC)  | Reason: Not specified
clyde60 Offline
#4 Posted : Tuesday, 15 April 2008 2:57:11 AM(UTC)
clyde60
Thanks, I will look at the bolts and get back to you. Are the inertia belts a straight replacement for the non-inertia existing belts?
Duzty Offline
#5 Posted : Tuesday, 15 April 2008 3:10:39 AM(UTC)
Duzty
yes they should fit straight in, they have the same mounting points as lapsash belts i think.
#6 Posted : Tuesday, 15 April 2008 8:16:10 PM(UTC)
You will need to use k2256 for the drivers side and k2257 for the passengers side. However, as they are horizontial mount retractable belts, you will need to frabricate a mounting point on your parcel shelf that is both horizontial and is strenghened sufficiently to pass a roadworthy. Some states may require an engineers certificate.
These belts are $110.20 each.
Duzty Offline
#7 Posted : Tuesday, 15 April 2008 8:48:37 PM(UTC)
Duzty
Bob, k2257 is lap/sash. Will he just need k2256 for both sides? And thats only if it is a 7/16" size bolt.
clyde60 Offline
#8 Posted : Tuesday, 15 April 2008 9:03:43 PM(UTC)
clyde60
Thanks, they are 7/16"
Duzty Offline
#9 Posted : Wednesday, 16 April 2008 1:17:32 AM(UTC)
Duzty
you will need the K2256 which is a Klippan brand seatbelt from your local Rare Spares/Auto One store. You can also buy a fitting kit (part# 1765170) to create your mounting points on your parcel shelf.
