7 Pages<1234>»
lxtoranahzute Offline
#21 Posted : Friday, 16 January 2009 7:25:00 AM(UTC)
lxtoranahzute
Removeing a windscreen without breaking it well you got to be supper paitient but 9 times out 10 u will break it so get a pro, but to stop the black **** sticking to everything talcom powders the go.Tight bolts crc or wd ofcoarse but sometimes a good wack on the end of it will free it up.
toptrix
vintageholden Offline
#22 Posted : Friday, 16 January 2009 7:51:58 AM(UTC)
vintageholden
dont buy a car at night
the next day you think........what the hell did i buy ....full of rust...
#23 Posted : Friday, 16 January 2009 9:00:36 AM(UTC)
Speaking of night , I was driving home in my first car at night and it was coughing an spluttering ,for some reason I pulled over and lifted the bonnet and saw all these sparks everywhere ,leads ,coil and distributer.
So since then I check this sort of thing by just lifting up the bonnet slightly to see any sparks.(It does work!)I found that out by accident.
Jim in adelaide
#24 Posted : Friday, 16 January 2009 9:58:50 AM(UTC)
Originally posted by john
to clean smaller greasy parts put them in a tightly sealed plastic jar with a bit of petrol put that in the boot or back of the ute and while your out doing your daily driving shopping etc they get a clean
General purpose paint thinners will bring a dismantled carby up like new, removes all carbon and fuel stains.
Soak parts in an ice-cream container o/night. (gets in your brain though)
Absinth Offline
#25 Posted : Friday, 16 January 2009 10:02:35 AM(UTC)
Absinth
If you are still using WD40 or CRC, do yourself a favour next time you go to buy some and get Inox instead. Far better product.
#26 Posted : Friday, 16 January 2009 11:49:39 AM(UTC)
THIS IS NUTS
THIS IS INSANE
Plastic jars with petrol? Ice cream container with thinners? Soaking?
Have any of you actually measured the amount of time (hours if not minutes) it takes for these solvents to eat through these general household plastics?
My tip is to find out a little bit about material properties before you spout off with these dangerous ideas, and if you want to use plastic containers with either of these solvents then at least quote a material specification so some fool can actually seek out the right polymer.
Thinners in an ice cream container? BWAHAHAHAHA give me a break. PLEASE
#27 Posted : Friday, 16 January 2009 12:34:14 PM(UTC)
As Tex says "learn how to read wiring diagrams", It saves heaps of time in diagnosis. Also remember your earths as they are very often the cause of a lot of faults, especially on EFI systems.
To save on fuses when looking for a short circuit in your wiring, Use a bulb hooked up across fuse terminals. When the short is present the bulb will light up and when it is fixed the bulb will go out. NOTE
A. (best done with the component at end of circuit removed so as not to get a dummy signal)
B. (Try it out first on a good circuit to get the hang of it.)
C. (As with using a bulb type lead light remember hot bulbs can melt carpet, seat covers, dash trim etc and sometimes cause fires so be careful please.)
Absinth, I"ll have to agree with you on the Inox, It would have to rate as one of the best consumable products I have ever used. The local farmers here use it heaps. The red soil has a tendency to seize up bearings and anything else with close tolerances, so it often gets called upon so that the job can get finished instead of spending the day in the workshop. (careful wont stop failed harvester bearings burning wheat crops though) 2 types that I know of, plain "INOX" that fizzes to penetrate in. and "LANOX" lanolin to help stop corrosion. Try your local gun shop as sometimes they sell it for under ten dollars, One parts shop here has it for over 20 and on average 12 to 14 dollars a can at the local hardware store.
#28 Posted : Friday, 16 January 2009 1:52:33 PM(UTC)
Ha! Ha! obviously you have no idea about the properties of plastics.
Try it!
Just dont breath in too much more thinners than you already have :-)
Posting without knowledge is also insane.
jabba Offline
#29 Posted : Friday, 16 January 2009 4:18:11 PM(UTC)
jabba
Another handy tip (rather than degenerating into the "you are talking rubbish" rant that these threads seem to generate) is the disposable latex or vinyl gloves you get in boxes of 100 to 200 from Repco, Supercheap, etc. Doesnt stop the grease from getting up your arms or in your hair, but you dont lose much if anything in ability to hold fiddly bolts, nuts, screws, etc and clean up time is much reduced.
Also, change them fairly frequently (they work out a few cents each) to reduce amount of grease you are putting back onto jobs.
Rather than pulling off plug leads to check for which cylinder is misfiring, use a timing light on each lead in turn. Much less likely to zap oneself, and if you shine on balancer you can see if the firing is consistent.
classic oz wreck Offline
#30 Posted : Friday, 16 January 2009 8:52:10 PM(UTC)
classic oz wreck
VERY IMPORTANT....when doing a resto...never ever throw anything out even if it looks rooted...often you will realise at the end of resto that you need that rooted bit as a sample or you cant find that insignificant mould that you could get easily 5 years ago ....i hear it all the time..i shoudnt have thrown that out....i purchased a 69 gto in june 2000 which had been off the road since 1989 and it came with a uteload of crap...i still have all the crap and it saved me heaps of trouble in the last few weeks...now on club rego...
www.classicozwreck.com.au
Bluez Offline
#31 Posted : Friday, 16 January 2009 8:58:24 PM(UTC)
Bluez
Good thread
When putting a HQ interior back into the car make sure you put the A pillar inner covers on before you put the windscreen in. Makes it very difficult if you put the screen in before, if you try to put them on after you risk cracking the screen.
Jesse Jesse Jesse, you've not got a sense of humour!
blue1avn Offline
#32 Posted : Friday, 16 January 2009 9:31:48 PM(UTC)
blue1avn
Before buying a new ride take a magnet with you when you look at it and put all over the car to help you find rust and bog. Would have helped me a bit but instead I found all the rust and bog later. Very frustrating and disheartening.
Peter
Absinth Offline
#33 Posted : Saturday, 17 January 2009 12:10:56 AM(UTC)
Absinth
Haha, made that mistake with a HQ tonner years ago, didnt crack the windscreen but spent friggin hours digging out black tar to get them to fit properly.
With HQ to HZ, if you leave the windscreen in when re-painting your car, DONT remove the rubber spacer blocks between the cowl and the bottom of the windscreen otherwise the next time it rains you get to have a shower while youre driving. On hot days the tar softens and the windscreen will slip down creating a gap at the top.
Thinners in an icecream container is not something I would recommend either, I did it many years ago to quickly clean out a spray gun and thought it would last a little longer than the couple of minutes it took to eat through the container. Thinners is stored in metal containers for a reason.
hg350gts Offline
#34 Posted : Saturday, 17 January 2009 5:16:22 AM(UTC)
hg350gts
Thought of another couple obvious ones
Keep your car regoed during resto..
A "quick tidy up" can easily morph into "huge horsepower bare metal restoration" after a daydream (and you know what / how much that requires)..
#35 Posted : Saturday, 17 January 2009 8:56:00 PM(UTC)
Yes I Do...!
Jim in adelaide
basketcasebear Offline
#36 Posted : Sunday, 18 January 2009 2:16:58 AM(UTC)
basketcasebear
make sure when using pintara long shanked windscreen wiper motors, for external elec window winders,,to get the nylon coupling shaft, milled by someone who has a lathe, dont try centering the coupling by hand,,
only basketcases do this!!
and when using pintara long shanked wiper motors for small electric winches,, for lifting tail gates etc,, you get the pulleys milled by some one with a lathe,,
dont try this at home,, only basketcases do this,
bcb
said the weathercock to the wind,> "how tedious and monotonous you are, can you not blow in any other direction, but in my face!"
and the wind did not answer, it just laughed in space.
k.g/
DOH!!!
adam PERTH Offline
#37 Posted : Monday, 19 January 2009 8:56:34 AM(UTC)
adam PERTH
before an engine swap, dump the radiator,.... then drive into the shed next to the hoist.
WANTED:
QR 662xxx
1984 WB oyster crashpad
1x15x8 Cheviot armoulite HQ
pair of 15" Dragway centrelines suit HQ
69HT_MUNRO Offline
#38 Posted : Monday, 19 January 2009 9:59:28 AM(UTC)
69HT_MUNRO
A mates Dad told me today that if you hook up a battery up to the wires that runs around you windscreen it melts the rubber and the windscreen comes out freely insteed of cracking it not sure if it works.
Cheers Stephen
[email protected]
http://gallery.oldholden.com/69HT_MUNRO/
Be careful about reading health books. You may die of a misprint.
[email protected]
#39 Posted : Monday, 19 January 2009 11:42:22 PM(UTC)
toptrix
to remove a bostic sealed screen.
always try to find wire ends first, if you do hook up 24V & heat up screen seal (1/2hr) & simply push out.
or if you cant find wire ends.
you will need the following;
a extra person inside the car.
a wound wire bonnet cable off a commodore or old piano string (solid wire will break).
a bottle/jar of degreaser & application brush.
First feed wire through seal into cab at top of screen, cut seal using a sawing action & liberally apply degreaser, whilst assistant helps maintain tension, take time to apply enough degreaser to stop seal re-sealing, take care on corners as wire can jamb or break on body joins.
once you have removed screen, you can use shellite or acetone to remove old seal. (dont clean the screen on or near the car, as these spirits will damage the paint on contact).
#40 Posted : Tuesday, 20 January 2009 1:51:50 AM(UTC)
put the parts you need to clean in large or small plastic type sealable jar with a bit of petrol or degreaser place in the boot of the car or back of the ute and while out for a drive they get a clean
Guest (13)
7 Pages<1234>»
This page was generated in 0.115 seconds.
