wimjack Offline
#1 Posted : Friday, 8 July 2005 6:51:46 AM(UTC)
wimjack
Does an XY 9inch Diff bolt straight in to an XB Falcon,or does it need to be modified?
jack
dave351cid Offline
#2 Posted : Friday, 8 July 2005 6:58:10 AM(UTC)
dave351cid
the XY diff will be to short for th XB think its an inch and a half or there abouts. the XB has a wider body and so the springs are spaced further apart
why not look for a 9 inch diff out of a XC 351 or 351 Fairlane - LTD as these will fit straight in an
old B`s go hard .
new B`s have air.
dave351cid Offline
#3 Posted : Friday, 8 July 2005 7:01:22 AM(UTC)
dave351cid
jack
while we are on the subject , you can often pick up an old fairlane for next to nothing and they are full of good parts
dave
old B`s go hard .
new B`s have air.
old B`s go hard .
new B`s have air.
Munromad2004 Offline
#4 Posted : Friday, 8 July 2005 6:34:31 PM(UTC)
Munromad2004
Dave351cid is correct. The XY diff is shorter by around 1.5 inches.
Take a look for an old ZF or ZG Fairlane (or obviously an XA or XB Falcon). These diffs will bolt straight in.
An XC Falcon or ZH Fairlane will also bolt in but there is a differenc
#5 Posted : Friday, 8 July 2005 9:38:36 PM(UTC)
#6 Posted : Saturday, 9 July 2005 12:10:34 AM(UTC)
Thanks for the advice.
I want to fit a set of 15x12 rims with 305 TAs to my coupe and thought it would be easier fitting an xy diff instead of getting mine shortened.Im currently running 15x10 rims with 295 TAs and noticed there is plenty of room between
Paul351xb Offline
#7 Posted : Saturday, 9 July 2005 5:01:02 AM(UTC)
Paul351xb
The XY diff should be fine for what you are wanting. Just make sure you have the offset of the wheels spot on so that you don't get any fouling.
Paul.
dave351cid Offline
#8 Posted : Monday, 11 July 2005 7:10:11 AM(UTC)
dave351cid
ok Jim5.0
i stand to be corrected
i did think that the springs were further apart on the later models but i could be wrong, wouldnt be the first time .
a quick stretch of the tape measure across the mounts will soon tell you.
dave
old B`s go har
old B`s go hard .
new B`s have air.
#9 Posted : Monday, 11 July 2005 11:58:26 PM(UTC)
Yes I thought that the spring saddles were different too but my brother said that they are not after he fitted XC disc brake 9 inch diffs to both of his XW's.
wimjack Offline
#10 Posted : Wednesday, 13 July 2005 6:23:31 AM(UTC)
wimjack
Thanks Guys
I think that will be the best way to go.Now for the hard part,Trying to find an XY 9in Diff.
jack
#11 Posted : Monday, 25 July 2005 8:19:30 AM(UTC)
gaasman Offline
#12 Posted : Tuesday, 26 July 2005 4:21:16 AM(UTC)
gaasman
Hi Wimjack. I can help you with an XY 9". Has been converted to XD disc brakes, has new rotors, pads and axle bearings. $1100 (less centre) and it's yours. I can help you out with a centre as well as a choice of ratios too.
#13 Posted : Wednesday, 3 August 2005 7:47:36 AM(UTC)
Theres a cat in the gold coast selling XY 9" diffs for $1000 bucks a throw he has one on e-bay now he also advertises in Parts Peddler.His number is 0407962089 they are out of Torinos actually but the same as XY 9" (he says). Stirling Performance (07)3274
#14 Posted : Wednesday, 17 August 2005 1:28:50 AM(UTC)
HI, I MIGHT BE A BIT LATE AS I HAVE JUST FOUND OUT ABOUT THIS SITE TODAY (i know i know where the hell have i been) BUT IF IT HELPS IT HELPS, I HAVE AN XB COUPE MYSELF, I BOUGHT A ZG FAIRLANE WITH A MILD 351C, C4, AND 9 INCH UNDER IT. I WASN'T SURE IF IT
#15 Posted : Friday, 21 October 2005 8:09:07 AM(UTC)
I HAVE AN XA SEDAN WITH A SHORTEND 9INCH IT IT IS 1.5 INCHES SHORTER THAN A XY DIFF AND HAVE 295 TA"S UNDER IT
#16 Posted : Friday, 21 October 2005 8:12:45 AM(UTC)
I HAVE A XA GT RPO WITH A SHORTEN 9ICH IT IS 1.5 INCHES SHORTER THAN A XY DIFF AND I HAVE 295 TA"S UNDER IT
This page was generated in 0.186 seconds.
