Were the HK GTS 307 Monaros released only as a 2 speed powerglide or were they also released as 4 speed saginaws like the 327?
I read somewhere that the HK GTS 307 was only released as an auto, just want to know the facts, if anyone knows.
Matt
Powerglide or Saginaw. The 307 4spd is basically the same car as a GTS 327, just minus the big tank and associated tank covers. Not much else is different.
Of course HK GTSs were built with Saginaw 4-speed gearboxes. It began like this. When the HK range was first released in early 1968, the 307 (5-litre) V8 was only available with a Powerglide. When the Monaro range was released in July 1968 the Saginaw 4-speed, which was standard on the GTS 327 model, was offered as an option on he rest of the HK range. They were even seen behind 6-cylinder engines which made the ute or van available with a 4-speed for the first time. This was because the Opel 4-speed (optional on sedans & wagons) was not offered on commercials. So, prior to July 1968 all Holden sales literature stated that the 307 was auto only. This is one of those things that some well-known motoring writers (who shouldve known better) have been spreading over the years. They seized on this sales info & it made them think that the 307 HK 4-speed was never made. 307 HK GTSs were more often seen with a Powerglide, but 307 Saginaws are still often seen around. From memory I used to own one, in the late 1970s. Also it was one of those rear instances where the manual version was more expensive to buy when new, than the auto version. Even in those days it would have cost GM-H more money to import a Saginaw than a good old Powerglide. Dr Terry. Edited by user Tuesday, 24 March 2009 7:14:16 AM(UTC)
| Reason: Not specified |
Byron, did the 307 4-speed GTSs get a dual exhaust system as standard? If they did, did they get the engine pipes which included the small extra mufflers up front like a 327? Did they also get the big radiator & 15lb cap? Dr Terry. |
So the HK GTS 307 4 speeds were only sold as special orders?
Holden didnt actually market a HK GTS 307 as a 4 speed saginaw?
Does a chassis number give any indication as to when a car was built? (say pre 26,000ss = Prior July 68 etc)
Approx how many 307s were released and how many approx would of been autos?
Sorry about the questions! But thanks for the replys :)
Matt |
Matt
No, they werent really special orders, they were just an option. A bit like an HQ 350 Deville, where the 350 & TH400 combo was an extra cost option. Most would have been made simply to fill retail customers orders. But not too many wouldve been ordered as regular dealers stock, just to have then sit on the front line next to the Kingswoods, awaiting sale. This is one of the reasons that factory a/cond is rare in early cars, most with fitted to fill a customers request & not kept as regular stock. These options were all quite expensive back then. I have no idea on build numbers, but HK 186S GTSs & 307 auto GTSs were more common on the road in those days. GM-H marketed the 307 Saginaw just like any other option. It gets a good mention in the HK Monaro sales brochure, so it wasnt kept a secret. There are some other guys on the forum who collect chassis, body & engine number & who can date a car down to a month of production, based on chassis number. Post your numbers & ask the question. I dont mind the questions, isnt that was this forum is all about. Dr Terry |
The "DOC" is the man to answer most questions!! yay for Dr Terry
307 had a single exhaust in HK and HT. I always thought the 307 and 327 type 1 shared the same radiator (auto cooler aside). When Ben Stewart reads this hell be able to answer properly. The 2 barrel and single exhaust is what made them less powerful than the 308 in HT. I had heard stories, but the latest AMC with the article about the 307 HK rally Monaros where they fitted the 327 exhaust tells the tale well. An original 307 manual fitted with the same carb and exhaust as a HT 308 got (same also as HK 327) is a pretty quick car. Probably as quick as a 327.
The other source of "307 only auto" could have come from HT where you couldnt get a 307 manual (although one or two snuck through).
Matt, remember HK was made at 5 x plants all with unique V8 engine and chassis number sequences so there will be 5 x starting points in V8 engine and chassis number for Monaro/manual release. Email me the numbers and ill see what I can tell you.
I think you will find the 307 auto myth started in about 1982/3 when John Wright wrote Monaro Mania in Street machine magazine. This was the change over from the van era to the street machine and Monaros, although only 14 to 5 years old, were already hot stuff, a bit like the VTs to VZs today.
There were also articles in Motor, Whels etc written by John or other journos, who copied Johns stuff. The interesting part about Johns work was he always quoted the fact that there were 19 engine gearbox combos. Here they are from the sales brochure:
Monaro
161 with 3 speed 161 with all synchro 161 with 4 speed 186 with 3 speed 186 with all synchro 186 with 4 speed 186 with powerglide 186S with 3 speed 186S with all synchro 186S with 4 speed 186S with powerglide 307 with 4 speed heavy duty 307 with powerglide
GTS
186S with 4 speed 186S with 4 speed heavy duty 186S with powerglide 307 with 4 speed heavy duty 307 with powerglide
GTS 327
327 with 4 speed heavy duty
So counted the 19 but failed to realize there were two mentions of 307 4 speed. (plus a mention of 186S saginaw)
Then when spotlight came out in 1991, it copies the same info again, however Tony and Peda Davies must have been working on different parts, as Peda points out nothing but auto and in the specs Tony has the rear axle ratio for 307 4 speed as 3.36.
The interesing thing is, as Terry pointed out, is the fact that the 4 speed saginaw behind a 307 was dearer than the auto, by as much as $135 in a Belmont sedan to only $75 in a Premier sedan.
In the Monaro they were $115 for a Monaro coupe and $85 in a Monaro GTS.
These prices are from a January 1969 price list so might vary from other earlier ones.
Other interesting info about these 307 manuals is the fact that most GTSs have radius rods.
My final word on the myth is the number of road tests that were done on these 307 4 speeds, there were two rally cars, red Monaro coupes, a GTS at release and a Premier wagon. The whole thing is just another "fact" that still to this day has to be explained, argued vigorously by people who have old street machine mags etc or Spotlight on Monaro, and perpetuated by people who build web sites with the info from these. But I suppose the truth about the HP block is one of those things that "people cant handle the truth".
Warren
Warren
They also missed 186 with heavy duty 4spd in Monaro, or was this not an option? In that 19 there is also 2 x mentions of 307 auto.
Byron
The heavy duty 4 speed on 186 and 186S on Monaro was never listed in the brochure for some reason.
The difference between a 307 4 sped and GTS 327 are as follows:
Engine including carby Dual exhaust Big tank Front sway bar Shocks Radius rods (although they appear to be optional on 307 4 speed)
The 307 4 speed was optional with air conditioning.
Price difference was about $260, about $7000 in todays money. This makes the 307 4 speed good value for money compared to the GTS 327 and heaps were made. Only real advantage of teh TS 327 was the big tank and extra BHP, but a bit of work to the 307, as Byron pointed out, would do wonders. Especially late in the mdel run with the second type 327 have the less powerful engine
As you can imagine, there would have been lots of 307 4 speeds made during the period that the GTS 327 was not available, due to too high a demand.
Warren
A mate in our car club had an original HK GTS 307 4 spd in restored cond, it was sold last year for $87,000.It now resides some where in Vic.
The car on the home page on my website is an original Inca Gold 307 4spd (now blue).
Warren, I thought radius rods were standard on HK V8 manual? Every one I have seen has had them including a Kingswood sedan (ive never seen a 307 4spd ute or van so I couldnt comment if they had radius rods or not). I also thought they were standard on HT/G 308 manual?
Thanks: 9 times Was thanked: 1 time(s) in 1 post(s)
A mate of mine has a HK GTS 307 manual thats been in his family since new and it doesnt have radius rods.
Byron,
I once thought they were standard 307 4 speed GTS. However after some discussion betwen Ben and myself when writing the book, we found that they were optional on 307 GTS only.
The reason for them being fitted to Kingswoods is unknown, however they would require the 6" rims and wheel spacers for clearance.
As for radius rods on HT, they are V8 manual GTS only, although 308 powered HTs, other than Brougham are rare outside GTS, so would not be 100% yes or no on this. But my info tells me radius rods should only be fittted to GTS V8 manuals.
Warren
Warren
And unfortunately some current magazines continue contributing to the situation particularly where Monaros are concerned. Just Holdens hasnt helped of late with the Silver Mink Monaro in issue 8.
Hi,
I had such a car back in the mid 1970s. It was a Burgundy Maroon with Parchment trim 307 manual GTS Monaro. The rear suspension in it was identical to the GTS 327. It was a good car while I owned it.
I like the comment that someone else thinks the Just Holdens magazine is terrible in its portrayal of Holdens. Perhaps the title should change?
I have seen that car Im sure. It must have been one beautiful thing when new. When I saw it, it had the ear converted to HT/G tail lights. Even with some primer patches and dusty it was one gorgeous car.
Gidday, I own a HK GTS 307 4speed and I know of two others around the traps. Mine doesnt have the radius rods but does have the attatchment points in the rear wheel arch. Whether they were fitted or no I have no idea. One of the other cars does have the radius rods. In all other ways however our cars are the same. When purchased my vehicle did have the single exhaust and you could hardly hear in going. Cheers Al
The HK Parts Catalogue lists the Radius Rods and Dual Exhaust for 327 only. As someone else pointed out, with various assembly plants and Dealer options, there were probably variations to this in practice.
