Chassis: HT 427XX S Body: 9XX-H5 Model: 80837 TH6 29XXX Trim: 1291-T4X Paint: 567-10976
What is the colour and trim please? When was approx build date?
10976 Monza Blue mettalic. 14x Twilight Blue
Hi 81837,
There is normally only one X in a Monaro set of numbers/codes and this is on the TRIM line.
The approximate build date is April 1970.
Thanks Shifty350, the Xs represent digits, its my mates new car and I didnt want all the numbers on display.
Being so late in the HT period, should this car have an ADR compliance plate?
Yes it should. All 1/70 onwards did.
Joined: 27/06/2009(UTC) Posts: 21  ![Australia Australia]()
How can you tell its april 1970?
I think you will find that they have worked this out via the small amount of info on the chassis/body numbers hence approximate build date Shifty350 is connected with Mr Ben Stewart who as we know has seen the most amount of numbers in this field.
