RussVRute Offline
#1 Posted : Friday, 15 July 2005 5:19:20 AM(UTC)
RussVRute
G'day All,
I was thinking of putting a VK injected motor (202) into the tonner,( I know where I can get one in good cond. if I really want it) and would like to know what the best way to go about that would be? e.g. put the head and injection onto the existing red motor, or transplant the whole engine, and if so is it easy to get the computer and sensors etc wired up? Also will it bolt up to my 4 speed ? is this too much trouble for no great benefit or is it worth the time and effort, and are the injected motors more fuel efficient and how much? any advice greatly appreciated. Thanks.
Russ
#2 Posted : Friday, 15 July 2005 6:39:30 AM(UTC)
Gday mate, The black motor head will go on to your red motor, but will need mods. I say it should bolt up to your 4-speed. There is a site made by a bloke name Sammy, he has done a competle gide on the mod.
#3 Posted : Friday, 15 July 2005 7:08:43 AM(UTC)
Sammy's page on VK EFI conversion is http://www.oldholdens.co...eficonversion/index.php
Cheers...Dave
#4 Posted : Monday, 18 July 2005 8:22:22 AM(UTC)
I did this conversion its fairly easy if you use patience. But make sure you get the engine part of the wiring harness, the fuel pump relay and socket, and the computer.
Take 40 thou off the head as the vK is about 8.8 : 1 while the older motors were ove
peter_flane Offline
#5 Posted : Tuesday, 19 July 2005 9:36:32 AM(UTC)
peter_flane
Sammy's page is great. The advantage of using the VK head on an older block is you will only have to comply with any pollution requirements of the block, thus eliminating the need for EGR etc.
Taz2 Offline
#6 Posted : Tuesday, 19 July 2005 4:36:09 PM(UTC)
Taz2
Mark Berner here in Tassie has also done this conversion into an HJ 1 tonner.
You can see Marks page on oldholden.com
In thrust we trust
This page was generated in 0.095 seconds.
