#1 Posted : Tuesday, 19 July 2005 11:26:48 PM(UTC)
team, i have a belmont well i think it is, how can i tell and is it on the VIN code or anywhere else.
thanx
#2 Posted : Wednesday, 20 July 2005 3:09:11 AM(UTC)
Hi Bro NZ.
Post the numbers of your body plate & the VIN plate (the VIN plate is the skinny one).
Dr Terry.
#3 Posted : Thursday, 21 July 2005 3:58:10 PM(UTC)
sorry Dr T, been unda the bonnet, its a 8M69LCJ35029Q, another plate has L20 JL2 - Wots JL2??? M for commercial?
#4 Posted : Thursday, 21 July 2005 4:36:16 PM(UTC)
Hi Bro NZ
Here's the breakdown of the VIN
8 = Holden
M = Belmont (for HQ)
69 = 4 door sedan
L = hi-comp 202 engine
C = 73 model year (built between 1/9/72 & 1/9/73)
J3 = body built in Melbourne (Dandenong factory)
5029 = body serial number for
#5 Posted : Thursday, 21 July 2005 7:16:28 PM(UTC)
Ben Stewart asked me about JL2 on a HQ Sandman production broadcast sheet the other day. It would be good to know what it is.
#6 Posted : Thursday, 21 July 2005 9:06:01 PM(UTC)
also guys is this motor with this model? OL216309
#7 Posted : Thursday, 21 July 2005 10:17:06 PM(UTC)
Yes. It's QL though.
#8 Posted : Friday, 22 July 2005 3:06:13 AM(UTC)
Hi Guys.
Yes, Byron is correct, the engine prefix is QL, often misread as OL.
The JL2 option number refers the power front disc brake option, although i've never seen this stamped on a body plate before.
Is this vehicle an NZ assembled car ?
D
#9 Posted : Friday, 22 July 2005 3:25:15 AM(UTC)
JL2 isn't even mentioned on the 2/74 HQ Sandman production broadcast sheet that I have. The particular van is a factory disc brake example, according to the DSC data under BRAKES and also on the GMH build records.
#10 Posted : Friday, 22 July 2005 4:30:35 PM(UTC)
Dr T yes i believe it could be as the plate does have GMH NZ printed on it and the plate number. Once again like a Kingswood S/W i enquired about, it also doesn't have a trim and body plate attached.
#11 Posted : Sunday, 24 July 2005 4:40:39 PM(UTC)
Once again guys - i have a kingswood dash in the Belmont, my speedo aint right - could it be i have the wrong gearing in the 3spd manual? and i found the temp wire off the sensor but the light comes on all the time when reattached - must I replace the sen
Edited by user Monday, 25 July 2005 3:05:27 AM(UTC)  | Reason: Not specified
#12 Posted : Monday, 25 July 2005 6:50:57 AM(UTC)
these links may help to identify which speedo gear you need
http://oldholden.com/?q=node/15435
http://www.oldholden.com...eedo_Drive_Gear_Colours
is your speedo needle flicking around or still smooth but just reading wrong?
if it's
Edited by user Monday, 25 July 2005 6:56:20 AM(UTC)  | Reason: Not specified
#13 Posted : Monday, 25 July 2005 4:28:40 PM(UTC)
cool cheers, could i have the wrong temp sender? one for a gauge with a needle rather than a light?
#14 Posted : Monday, 25 July 2005 10:23:04 PM(UTC)
Bro NZ
The VIN number of 8M69LCJ35029Q you quoted is missing a digit.
Apparantly NZ Holdens always have the mechanical option on a plate, that is why JL2 is there. A lot of NZ HQ-HZ GTS's had G80 (LSD) listed.
#15 Posted : Monday, 25 July 2005 11:39:22 PM(UTC)
ar yep noticed last time - a 2 for the serial numba. wot you reckon with the mechanical plate as mine don't have the G80 stamped and theres no grinding marks? I'll have a look at the diff plug see wot its got - L8TR.
#16 Posted : Tuesday, 26 July 2005 3:20:10 AM(UTC)
Hi Bro NZ.
When you say you have a Kingswood dash in a Belmont, you mean different instruments, is that correct ?
In Australian HQs, the Belmonts & Kingswoods use the same instruments. Do the NZ Kingswoods get the GTS type set-up or the one with the
#17 Posted : Tuesday, 26 July 2005 5:20:16 AM(UTC)
Where does the 2 go? You misunderstood on the G80 - I meant it appeared on GTS's. Yours is not an original LSD fitment so it won't have G80.
#18 Posted : Tuesday, 26 July 2005 6:28:42 PM(UTC)
Dr T - ah hah, me belmont (hurrah) has got the 2 gauges and the rest is lights, but the sad thing its got kingswood label attached, as i have read in Ellerys manual you're spot on, Kingswood and Belmont have the same xcept in my case i need a name change.
KiwiHQ Offline
#19 Posted : Wednesday, 27 July 2005 12:02:03 AM(UTC)
KiwiHQ
If your speedo is out it can be due to the profile of your tyres as well. I have low profile tyres and 52mph is acutally 62 mph.
Rock n Roll
Rock n Roll
#20 Posted : Wednesday, 27 July 2005 5:10:15 AM(UTC)
i think you mean overall wheel + tyre height?
This page was generated in 0.114 seconds.
