eskimo_joe777 Offline
#1 Posted : Friday, 22 July 2005 6:28:59 AM(UTC)
eskimo_joe777
I was reading a Mag and there was an ad for stroker kits and i saw that u can bore out a 308 and 350 to the same size(388) and was wondering which would be ther better engine to do this to or if they would be the same? I was told that the 308 bored out will have more torque if they r both bored out to the same wouldnt they be the same?
Cheers Justin
#2 Posted : Friday, 22 July 2005 7:12:45 AM(UTC)
they will be bored, and stroked (new crank)
the 350 can go further than 388 (as far as i know they can use a 400 SB crank)
the 308-388 conversion is good but the more cubes the better!
ps..... check this out.....
500+ cubes Small block on the way wi
Taz2 Offline
#3 Posted : Friday, 22 July 2005 4:24:55 PM(UTC)
Taz2
Steve Coads Monaro has a 350 chev motor bored & stroked to the maximum which from memory is 416 ci.
Car produces something like 720 hp.
Try his website for details: stevecoad.com
In thrust we trust
