austbubba Offline
#1 Posted : Thursday, 14 May 2009 1:08:58 AM(UTC)
austbubba
Have the following items for sale.
308 motor, complete (tri),dyno sheeted 425hp,best of everything ,Higgins heads,Blackwell dyno,to many mods to mention.
M21 box's ,both with bell,shifter.
Ice ing-system, complete top of range.
355 stroker crank and rod's,Pistons,all new.
Oil pump hp
202 HQ-ACL race pistons,bearings,anti-pump lifters.
Lots and lots of treasure!!!!!!!!!!!
ring for more details.0488084799
Austbubba
Austbubba
nokternalmotors Offline
#2 Posted : Sunday, 24 May 2009 11:56:02 PM(UTC)
nokternalmotors
what price you chasing for the 355 crank, rods and pistons? and what brand are they cheers
austbubba Offline
#3 Posted : Monday, 25 May 2009 12:37:47 AM(UTC)
austbubba
Eagle and Holden , Piston are KBs. As i am not needing them
$750 plus postage, 0488084799
Austbubba
Austbubba
#4 Posted : Monday, 25 May 2009 4:20:37 AM(UTC)
the crank will break, they are having trouble with them lately
We Wreck Junior Offline
#5 Posted : Monday, 25 May 2009 4:27:16 AM(UTC)
We Wreck Junior
we will buy it off you for $50, saves you destroying a good block.
i love Carlton FC, mossimo turtlenecks and my mum.
#6 Posted : Monday, 25 May 2009 4:36:07 AM(UTC)
your learning quick nefew, stick with me you be wearing diamond rings in no time
austbubba Offline
#7 Posted : Monday, 25 May 2009 5:18:46 AM(UTC)
austbubba
Good to see the positive outlook, I have used them for a few years ,and havent broke one yet.
Tell you what, give me a VT block and ill give you Fifty bucks
Right radius and correct index ,zero balance and it will see 450hp no problem, who builds your grenades!!!!!!!!!!!!!!!
Austbubba
Austbubba
Custom Offline
#8 Posted : Monday, 25 May 2009 5:49:55 AM(UTC)
Custom
You sound like your in the know bubba.
What can you do for my 2.4 Rodeo.
#9 Posted : Monday, 25 May 2009 6:38:01 AM(UTC)
Austbubba
well, speed pro distribors have now stopped selling them, and HPW in syd are refusing to discuss the problem. they have had 5 break in the last few months, and 2 cleveland cranks breaking, and the keyway is holding the strker 351 together.
no one builts my grenades, its the quality of the trash we get theses days that help them grenade, mr bubba, give them a call to discuss, 03 9794 5177
austbubba Offline
#10 Posted : Monday, 25 May 2009 4:16:50 PM(UTC)
austbubba
Now we have more info,I have had this batch of cranks for 3 years.
All new stock ,As with most Professional Engine builders ,There is a Process to follow and industry standard mag/test and other procedures will save alot of Heartache, as to the origin of so-called eagle or cheap copys,Let the Buyer beware!!!!!!!!!!.
5 cranks in a few months ,tends to point to a heat treatment or a base metal failure would be the first area in check.
I am not saying that it cant happen but to condem all eagle cranks ,
to this identified failure is somewhat extreme.how many cranks are out there compared to failures, How many cranks are reboxed to reflect branding and not origin??????.
Austbubba
Austbubba
#11 Posted : Monday, 25 May 2009 4:46:04 PM(UTC)
well, thats true. there must be a manufacturing fault..
so far seems to be 308 that are failing, and also cleveland when going to 393 cubes. like you say, buyer beware!!
but then again, who knows these days
Allan Offline
#12 Posted : Tuesday, 26 May 2009 5:13:54 AM(UTC)
Allan
What are you asking for the M-21?
Allan
[email protected]
austbubba Offline
#13 Posted : Tuesday, 26 May 2009 7:42:31 AM(UTC)
austbubba
Just found some more treasure.
2 sets of Performance wheels, 15x8 Minilites/+Challengers full set of each with nuts and caps new in boxs.
Disc brake rear end, 308 ratio hq-hz sedan
Banjo 3.55 fine spline,and axles.
Honda 3.5kw slient Generator
300mm Hq front brake set-up,Imported from USA, FOR Grp Nc race car
4 piston ali calipers (AC-DELCO C4) and all hardware to suit fit-up,1-1/8 master cly,braided lines,rotors (corvette 32mm) hubs and long studs.
Have lots of small bits and pieces,electric pump and lines etc.
Too much too list all.
Austbubba
Austbubba
MackaD Offline
#14 Posted : Sunday, 21 June 2009 5:55:04 AM(UTC)
MackaD
How much for the 308?
[email protected]
This page was generated in 0.159 seconds.
