bronsonHX Offline
#1 Posted : Tuesday, 19 May 2009 6:03:55 AM(UTC)
bronsonHX
i have a 76 HX with a standard 173 and wondering what to do to it first. it already had extractors when i bought it, and maxes out at about 130km/h. im looking to get this a bit higher or even just more torque. any suggestions?
#2 Posted : Tuesday, 19 May 2009 6:08:01 AM(UTC)
why would you want to go any faster, the max speed limit is only 110km/h, lol
#3 Posted : Tuesday, 19 May 2009 6:14:42 AM(UTC)
are you just after high speed or do you want more power all round?
what is your diff ratio?
do you have a points dizzy or electronic HEI? if you have points i would recomend changing to HEI
if your really serious about spark then also get a set of brisk plugs
do you have a standard carby? if so maybe upgrade to a 34 adm weber (xf carby)
#4 Posted : Tuesday, 19 May 2009 6:16:34 AM(UTC)
easiest way is to put bigger engine in it
greenhj Offline
#5 Posted : Tuesday, 19 May 2009 6:55:45 AM(UTC)
greenhj
Was thanked: 15 time(s) in 13 post(s)
if its a low comp, its nothing a 4/71 wont fix lol.
seriously though, take whatever money you plan on spending and just v8 it, sell the 173 to some anal torana guy (sorry restorers, im only kidding)
if you cant have the v8 for bullsh1it transport reg reasons, do yourself a favour and bung a 202 in, use whatever good gear you have already on the 173, and FEEL THE POWER BABY!
11.52@115mph street trim,
Edited by user Tuesday, 19 May 2009 6:58:02 AM(UTC)  | Reason: Not specified
Custom Offline
#6 Posted : Tuesday, 19 May 2009 7:13:04 AM(UTC)
Custom
I would look at trading it in on a 1968 Corolla like this one.
It does look a bit gay but with its 1.1L 60hp engine and 4 spd gearbox it will gauranteed run rings around a big ole kingswood packed with a 173.
Good luck.
Edited by user Tuesday, 19 May 2009 7:15:36 AM(UTC)  | Reason: Not specified
bronsonHX Offline
#7 Posted : Tuesday, 19 May 2009 7:24:54 AM(UTC)
bronsonHX
haha yeah i know, but my mate has a HR with a 202 in it that does 94 mph or so, so i need to top that or at least give him a run for his money. and im only on red Ps so cant get a V8 for a few years, otherwise id already have dropped something with an extra 2 cylinders in haha.
David Offline
#8 Posted : Tuesday, 19 May 2009 7:51:06 AM(UTC)
David
The Corolla is in great nick. Toyota made a good reliable car there.
BronsonHX, Id go the 202, but if you intend to keep the 173, why not fit a 186S twin throat carby and inlet manifold?
David
HQforme Offline
#9 Posted : Tuesday, 19 May 2009 8:05:39 AM(UTC)
HQforme
Google! This is probably the most common question in all of Holdens history. How to improve a Red6.
If youre not up to opening the motor, go HEI igniton, which is almost a total bolt in job, just one tricky wire to find. Youve got the extractors already, which is nice.
"Silly modern cars"
bosko Offline
#10 Posted : Tuesday, 19 May 2009 8:07:02 AM(UTC)
bosko
love the KE10, great little cars, gearboxes a bit weak
vintageholden Offline
#11 Posted : Tuesday, 19 May 2009 8:09:02 AM(UTC)
vintageholden
161 head........ ported .........
http://forum.n12turbo.co...7e2da7ea9524499568be5f71
extractors
twin strombergs or 2" su,s
thermo fan
efi dizzy
or bore the motor with flatop pistons
mild cam
http://www.hotsixes.com/hotsixes/?page_id=3
Edited by user Tuesday, 19 May 2009 8:12:38 AM(UTC)  | Reason: Not specified
JBM Offline
#12 Posted : Tuesday, 19 May 2009 8:15:12 AM(UTC)
JBM
Give it a decent tune up, ie set the timing, gap the plugs, change the air and fuel filters, get the auto serviced if its a trimatic, check for vacuum leaks. These are cheap and simple ways to improve performance but to increase your top speed you need to increase HP or reduce weight, start with the rear venetians and the front visor. ;)
The HX motor would be no good to the "anal" Torana guys because it wont have the correct engine number prefix, even if the date code was an exact match.
James
bronsonHX Offline
#13 Posted : Tuesday, 19 May 2009 8:37:24 AM(UTC)
bronsonHX
haha yeah ive done away with most of the old man style things, although it does look good with the set of whitewalls i put on. i was thinking maybe a bigger carby and new camshaft. i think the bloke who i bought it from took the 173 out of an LJ torana, as it originally had a 186
JBM Offline
#14 Posted : Tuesday, 19 May 2009 8:41:42 AM(UTC)
JBM
I thought the 173 was a bit old for the HX, it should have been a 179 or 202.
James
bosko Offline
#15 Posted : Tuesday, 19 May 2009 8:45:55 AM(UTC)
bosko
no, it didnt
Absinth Offline
#16 Posted : Tuesday, 19 May 2009 10:36:24 AM(UTC)
Absinth
6 cyl HX was only available with 2.850L - 173 and 3.300L - 202.
MrPink Offline
#17 Posted : Tuesday, 19 May 2009 11:18:08 AM(UTC)
MrPink
Well that figures! I can see it parked outside the toilet block now!
#18 Posted : Tuesday, 19 May 2009 6:21:29 PM(UTC)
Your best bang for buck will be to go and find a good working red 202. You already have extractors, so just add a HEI dizzy and a 186S inlet manifold and 253 WW Stromberg or Falcon 2 barrel Weber. If you want to spend a few more bucks a mild cam also, but plenty of secondhand 202s are around with work done.
JBM Offline
#19 Posted : Wednesday, 20 May 2009 4:29:24 AM(UTC)
JBM
I was just showing off my lack of Holden 6 knowledge, sorry.
Guest (11)
