HQforme Offline
#1 Posted : Wednesday, 20 May 2009 8:15:47 AM(UTC)
HQforme
So as mentioned elsewhere i was car 3 in a four car end-to-end. Nothing could be done, so now its all about fixing it. I've stripped everything forward of the firewall, cause it's all useless bar one inner guard.
I've measured the subframe tips and they're a little different. Half an inch-ish, max inch? I don't even know if it happened in the accident or was always that way. Certainly never had perfect panel gaps. Haha. But was thinking, while it's apart, why not try get it as straight as possible.
Question is, how do i know which is the better starting point? Or is the a redundant question?
"Silly modern cars"
BREDBO Offline
#2 Posted : Wednesday, 20 May 2009 8:27:09 AM(UTC)
BREDBO
Measure from the rear axle to the front axle with the steering straight.Can measure from edge of rim to edge of rim on both sides,this will show any mis alignment of chassis rails
bosko Offline
#3 Posted : Wednesday, 20 May 2009 8:36:08 AM(UTC)
bosko
maybe improve your driving skillz before you start on the repairs
HQforme Offline
#4 Posted : Wednesday, 20 May 2009 10:27:44 AM(UTC)
HQforme
Maybe f*** you. An accident is no laughing matter, and it was completely out of my hands. Not at fault, thats why there was no neg driving charge. And now i have to rebuild a car that ive put a lot of time, effort and money into, because of someone elses mistake.
BREDBO, thanks for helping.
Edited by user Wednesday, 20 May 2009 10:35:37 AM(UTC)  | Reason: Not specified
"Silly modern cars"
classic oz wreck Offline
#5 Posted : Wednesday, 20 May 2009 7:53:41 PM(UTC)
classic oz wreck
quite often in hq up with the half chassis a hit like that will not bend the subframe but move it on its rubbers..easy fix...
www.classicozwreck.com.au
HQforme Offline
#6 Posted : Wednesday, 20 May 2009 10:57:58 PM(UTC)
HQforme
Ah yes, good point. Cheers. I think i was actually given your number as a place for panels? Are you in Toronto? Ive just bought an entire front end off ebay for pocket change. Looks half decent but i think ill run that while i rebuild a proper set of panels.
"Silly modern cars"
#7 Posted : Thursday, 21 May 2009 12:45:03 AM(UTC)
classic oz wreck
yes thats me...
petaus Offline
#8 Posted : Thursday, 21 May 2009 5:08:40 AM(UTC)
petaus
as oz say if it,s up the bum hit there usally square hit,somtimes the ralis can go up or down,but id say on one of then you would be ok
HQforme Offline
#9 Posted : Thursday, 21 May 2009 7:28:19 AM(UTC)
HQforme
Thing is, i was slightly crooked when i hit. I was trying to steer away when i saw i couldnt stop in time. Crooked to the point where the whole front still copped the hit, but the right front headlight survived, and the right inner guard was the only panel not bent. Im basically trying to determine if the left rail is in, even in and down, or the right is up, maybe up and out. Or both just out.
Ill start trying to find straight lines and see how i go.
Thanks guys.
Oz, might give you a call sometime soon. Guy who put me onto you is a straight up bloke, been around a long time, and you were the first people he recommended!
"Silly modern cars"
on the Gear Offline
#10 Posted : Friday, 22 May 2009 2:48:45 AM(UTC)
on the Gear
THEY NORMALLY BEND JUST BEHIND THE BUMPER HAR BOLTS ON THE CHASSIS.
Browno Offline
#11 Posted : Friday, 22 May 2009 3:23:56 AM(UTC)
Browno
You are a member of these groups:: Registered
any pics?
Drive It Like You Stole It......Drive it like you own it
HQforme Offline
#12 Posted : Friday, 22 May 2009 5:12:56 AM(UTC)
HQforme
On the gear, id say youre on the money mate.
Browno, check my new topic.
"Silly modern cars"
#13 Posted : Friday, 22 May 2009 10:03:39 PM(UTC)
classic oz wreck
lookin at the pics in your other thread your left rail is bent to the left....fairly easy fix on those old girls..best to ring me and i can tell you how...also be aware that if you change the whole subframe you have to cancel your rego and rerogo as you are changing the chassis number and therefore the main identity of the car...greg 02 49594546
This page was generated in 0.123 seconds.
