nokternalmotors Offline
#1 Posted : Monday, 25 May 2009 3:40:41 AM(UTC)
nokternalmotors
i have a pair of v8 heads in my shed, said to have been taken off an A9X to put alloy heads on. now ive been told these heads are sought after by torana collectors wanting original matching numbers. so can anyone please tell me what the correct casting numbers are so i can check these heads. cheers
Custom Offline
#2 Posted : Monday, 25 May 2009 3:56:33 AM(UTC)
Custom
Yep and once youve found out they are A9X heads you can ask a small fortune for them.
Good O
JBM Offline
#3 Posted : Monday, 25 May 2009 4:15:23 AM(UTC)
JBM
The A9X had a stock 308 in it from factory, stock block, stock heads same as the HX or HZ.
The have the same part numbers and the casting date will determine their value for a particular car.
Dont get too excited they arent a performance item.
James
#4 Posted : Monday, 25 May 2009 4:35:47 AM(UTC)
nokternalmotors
im aware that they arnt a performance item, im only after the casting date to determine what particular car they where for. cheers
#5 Posted : Monday, 25 May 2009 4:52:24 AM(UTC)
Any 308 Holden built at the same time as A9X, or A9X.
Custom Offline
#6 Posted : Monday, 25 May 2009 5:42:32 AM(UTC)
Custom
Awe Spewin! Thatll knock the arse out of the price you were thinking of asking.
#7 Posted : Monday, 25 May 2009 5:46:18 AM(UTC)
They could also be 253 heads from the same era.
For each version there is no difference between standard heads on 253 or 308.
Dr Terry.
#8 Posted : Monday, 25 May 2009 6:01:52 AM(UTC)
DOES THAT mean i got to buy every 253-308 head from that era???
Custom Offline
#9 Posted : Monday, 25 May 2009 6:03:11 AM(UTC)
Custom
HA! The same as 253 now.
Well.
Ill give you 25 bucks for em. Theyll make good book ends.
#10 Posted : Monday, 25 May 2009 6:08:32 AM(UTC)
Well.
hahahahahahaha, gotta ;ove this forum, its the only one in which we can all have a larf in, cos we have a sense of humour.
notice how all the "numbers" and "cotton wool car" pple such as jimmy and D.A aint having a larf with us??????????
look what they are missing out on!!
#11 Posted : Monday, 25 May 2009 6:23:48 AM(UTC)
Dr Terry.
Very true. Me thinking with blinkers on again...
Although I think it would be stupid to do so, someone out there would probably pay more for them simply because they have the right casting date for an A9X. Why? Beyond me, as you cant even see the damn casting date. Very different to Chevs where they at least have a casting mark on the end. Stick them on Ebay with the casting date shown and if its correct for A9X someone will buy them.
Custom Offline
#12 Posted : Monday, 25 May 2009 6:27:05 AM(UTC)
Custom
AH see! EBAY pops its head up.
The reason for the initial inquiry.
#13 Posted : Monday, 25 May 2009 6:29:35 AM(UTC)
Dr Terry.
see byron
this re affirms my point, that holden numbers ppl really have no idea, and should put thet valuable time into making improvements into the car, not worrying about cast numbers that really mean nothing, at least ford numbers actually mean sometheing
#14 Posted : Monday, 25 May 2009 6:38:08 AM(UTC)
Correct, it means they were made by Ford, hence more likely to rust!
If they are sitting there collecting dust why not put them on Ebay? Thats what its there for. And if someone choses to pay good dollars for them good luck to them. Better than idiots paying bucks for air that Madonna breathed or sheets Julia Roberts slept in.
Edited by user Monday, 25 May 2009 6:38:52 AM(UTC)  | Reason: Not specified
#15 Posted : Monday, 25 May 2009 6:46:11 AM(UTC)
nokternalmotors
sorry everyone for using this forum to ask a qustion and not just for telling jokes, seems you have to be a clown to use this site these days. cheers
