#1 Posted : Saturday, 30 July 2005 2:47:50 AM(UTC)
over night the fuel in my rochester runs out and the car wont start until filled again. Is this common and any surgestions on fixing?
Craig
#2 Posted : Saturday, 30 July 2005 3:18:39 AM(UTC)
Not my department too much - havent seen that before!! Check for leaky seals around the carby, check your breather lines for the return to the tank, if its running back overnight, there's a leak somewhere!!
crowe Offline
#3 Posted : Saturday, 30 July 2005 5:44:11 AM(UTC)
crowe
Yes this does happen. I think that maybe as the motors hot the fuel might evaporate away over night. During the day it will start stright away between stops so the fact it sits for a longer time over night I think that thats the situation. The only grace
#4 Posted : Saturday, 30 July 2005 7:47:41 AM(UTC)
yes thats right,all day it will start first go. it has a edelbrock manifold on it maybe they run hotter.not water cooled.
gaasman Offline
#5 Posted : Sunday, 31 July 2005 8:31:09 PM(UTC)
gaasman
Hi Craig.
It may be siphoning through the accellerator check valve as well when the fuel is hot. Might need to be dismantled, cleaned and re kitted.
#6 Posted : Saturday, 9 December 2006 12:11:12 AM(UTC)
Maybe faulty valve in fuel pump allowing fuel to syphon back.
#7 Posted : Saturday, 9 December 2006 9:42:05 AM(UTC)
Rochesters can have a problem with the well plugs in the bottom of the main body leaking and this can cause your problem.
