Allan Offline
#1 Posted : Thursday, 28 May 2009 8:12:17 PM(UTC)
Allan
Hi Guys,
I have a red 308 V8 out of a H series holden?, it has a pollution manifold on it, and it is bolted to a Turbo 350 automatic.
My question is can I bolt a M-21 four speed to the 308?
A mate reckons because the block is "Chev" pattern and I will need an adaptor? I disagree with him because I cannot see why Holden would make a seperate "manual" and "automatic" block. I realise that a trimatic will not bolt up to it but surely the M-21 will?
Allan
MrPink Offline
#2 Posted : Thursday, 28 May 2009 9:01:08 PM(UTC)
MrPink
Your mate is correct there are 2 bolt patterns.
One for Aussie boxes and the other for American.
bosko Offline
#3 Posted : Thursday, 28 May 2009 9:01:44 PM(UTC)
bosko
are you sure its out of a H series? HD HR and HK didnt come out with 308s
#4 Posted : Thursday, 28 May 2009 9:06:25 PM(UTC)
Allan
Just buy a Chev to Aussie 4spd bellhousing. You just wont be able to use the factory rat-trap setup without mods. Try to use full cable or hydraulic. If its a factory combo ie 308 TH350 itll be late HZ or VB Commodore, so ZT, 11ZT or VT prefix on the engine number.
#5 Posted : Friday, 29 May 2009 3:52:53 AM(UTC)
"H series" usally means HQ-HZ, there are 2 differnt stud patterns, turbo and trimatic, you have 2 options to make a 4 speed fit you engne
1, do as HK1837 says
2, get you block machined to suit trimatic pattern, this is cheap and easy if your block is stipped for a rebuild, but if it is in the car running then it is a BIG job
i have seen adaptors, but i dont know how good they are
bosko Offline
#6 Posted : Friday, 29 May 2009 3:59:03 AM(UTC)
bosko
no, "H series" is a term dreamed up by morons who dont realise there are other models that start with H
the same morons devised the terms "styleside" for utes and "door skins" when they are talking about door trims.
usually has two us
#7 Posted : Friday, 29 May 2009 5:19:47 AM(UTC)
bosko, i cant belive im saying this, but... i agree with EVERYTHING you just said, even the spelling correction
#8 Posted : Friday, 29 May 2009 6:20:49 AM(UTC)
Just be careful on the bolt pattern change. You cant do it on HQ and earlier 253/308s.
Almost forgot, Bosko is right too. HQ-WB is really W series.
Edited by user Friday, 29 May 2009 6:22:08 AM(UTC)  | Reason: Not specified
#9 Posted : Friday, 29 May 2009 8:18:05 AM(UTC)
110% correct !!
#10 Posted : Friday, 29 May 2009 8:38:19 AM(UTC)
All good information regarding the different bell housing patterns.
The upside to having a turbo pattern 308 is that you can bolt any VN-VT 5 litre T5 to it as all of the V8s were turbo pattern by the start of VN V8 production. That becomes an easy upgrade for you.
Yes at first it sounds crazy having two different bell housing patterns on what is essentially the same engine but it was probably cheaper and easier to change the block slightly than it was to convince GM in the USA to make TH350 and TH400 transmissions with a "Tri Matic" style bell housing.
In hindsight they probably should have made all 253s and 308s with the Turbo pattern block and make the trimatics and manuals with bell housings to suit but they obviously had a good reason not to.
If at first you dont succeed then skydiving is not for you.
toms-HZ Offline
#11 Posted : Friday, 29 May 2009 8:42:36 AM(UTC)
toms-HZ
Was HK HT HG called the "HK" series?
toms-HZ Offline
#12 Posted : Friday, 29 May 2009 8:53:08 AM(UTC)
toms-HZ
Originally posted by Allan
Hi Guys,
Allan
Others did the same with blocks. Mitsubishi Austraila had two differant blocks in the early 2.6 liter Sigma (Astron motor). The auto cars used a small patern and the manuals run a large patern. They did this by memory as the Auto used was the same as the 2 liter and that box was made in Australia.
anonymous Offline
#13 Posted : Friday, 29 May 2009 6:54:05 PM(UTC)
anonymous
W series ? 110% do you get that when you add in the WH WK WL WM
Bolt pattern
Would you put a Tri-matic behind a 350 .No,but it would be easy to pull out the 253 or 308 and drop in a 350 if the bolt pattern was the same
To stop you doing this GMH made a Tri /Aussie block
#14 Posted : Friday, 29 May 2009 8:02:16 PM(UTC)
Yes, that is correct. In the GM alpha numbering series there are T cars, V cars, J cars & W cars etc.
V cars are Commodores e.g. VB, VN, VT, VE etc.
W cars are the next size up:- HQ, HZ, WB, WH, WM etc. Have a look at the body plate numbering of an HJ KIngswood:- 8WN69
Yes, there is overlap, like VQ to VS Statesman & Caprice IMHO should have been classified as W, but they werent.
#15 Posted : Friday, 29 May 2009 8:29:57 PM(UTC)
Bolt pattern
When the 253 and 308 were being developed new EHs were in Holden showrooms and the 350ci SBC was also on the drawing board. At that stage the trimatic would have been in design stage too. Not sure why the different bolt pattern, it even probably cost GMH money with the Powerglide into HT as special bellhousings were required to adapt the 6cyl glide to the Holden V8 whereas with a Chev pattern they could have just used the 307/350 one piece Powerglide. And its easy to do exactly what you say with HJ-mid WB as these have TH400 and TH350 standard.
On the above, does anyone know why the 253/308 Powerglide in HT (which uses the 6cyl case) uses the Chev V8 powerglide extension housing and hence rear mount? It also uses the Chev V8 powerglide speedo cable and hence needs the extra hole sawed in the firewall for the LH side cable. Furthermore the Holden V8 glide uses the Chev V8 glide column shift setup which is much more complicated than the 6cyl version. If theyd kept the 6cyl extension housing they could have used the 6cyl rear mount and its simpler crossmember plus not had to saw the extra hole in the firewall? Plus deleted the Chev V8 column shift linkage. Was it because the only car at HT release to have a Holden V8 and glide was the Brougham and it was never intended to fit the Powerglide to any other Holden as the trimatic was due for release?
To add to Dr Terrys post, there was also the U series ie LH, LX, UC although Holden botched that a little and had the LH and LX as V series but fixed it at UC.
#16 Posted : Saturday, 30 May 2009 3:03:11 AM(UTC)
Its easy now, to go back in history & say what should have been done. But look at it from an early 60s point of view.
As HK1837 has said, the 253/308 design began back in the EJ/EH era. In those days there was no TH350 or TH400. In the US the SBC still had teething problems & wasnt yet the proven package that we see today. Rather than use a yank design from any one of the various GM divisions, GM-H wanted to build there own engine, also one which weighed less than the US iron. All the different GM divisions had their own bellhousing bolt patterns, so do you pick one of those, or design your own. They designed their own !!
When they were designing the Holden V8, they knew the Tri-Matic was coming but it was from Europe & not intended for use behind V8s. They figured that because no other suitable 3-speed automatic was currently available, that they would just upgrade the Tri-Matic & build it here. (The early Tri-Matics were made in France). They did this, but for the 308, when the TH400 became available, they altered the bellhousing pattern & used the TH400 from HJ onwards.
To answer the query re:- the 308 Powerglide, they werent only fitted to HT Broughams. Any HT 308 auto would have been a Powerglide (except the last month so, when the Tri-Matics came online) & the same with HT 253 autos. It wouldnt have been too hard to make & use a different bellhousing, they had been doing this on 6-cylinders since HD. GM-H had been manufacturing Powerglide torque converters , bell-housings & extension housings in Australia since late 1964 to suit our RHD 6-cylinder application & to keep up the Australian content. The 253/308 Powerglide also uses a gear-set the same as the 6-cyl with a lower 1st gear than the Chev V8 version..
They couldnt use the 6-cyl style column shift cross shaft set-up because the US bell-housing had no provision for it. Besides they had already been using the V8 style set-up in Chevs & Pontiacs that they were building here at the time. They probably figured most V8 Powerglides were going to be T-bars anyway.
In hindsight it is easy to say they should have had the Chev bolt pattern from day 1, but it didnt go that way. BTW in South Africa they use the Tri-Matic behind their Chev 4 & 6-cyl engines. These have the same bolt pattern as the V8, so there is a Tri-Matic to Chev bellhousing made for the purpose.
Dr Terry.
Edited by user Saturday, 30 May 2009 3:08:57 AM(UTC)  | Reason: Not specified
#17 Posted : Saturday, 30 May 2009 3:30:37 AM(UTC)
Terry, I think I made my question confusing. I meant at HT release the Brougham was the only Holden V8 engine with a powerglide (with removable bellhousing) as you couldnt get a 253 auto and the 307 used the Chev powerglide. So what I meant was why didnt Holden use the 6cyl Powerglide extension housing and column shift with the Holden V8 powerglide? It all fits. So I was wondering if the Holden V8 powerglide in HT was meant to be a stopgap to fill in until the Trimatic arrived hence it was a bit of a mix and match affair?
Guest (5)
