Gday guys
would running a red 253 motor (253H prefix) on unleaded petrol have any bad effects. If yes what is the best way round this..??
Any feedback would be awesome. Thanks.
just add a additive like flash lube, or if you have gas heads then dont worry about adding anything at all
Is it an expensive process getting the heads redone.
about $600 flash lube is $65 from supercheep Edited by user Thursday, 4 June 2009 8:21:31 AM(UTC)
| Reason: Not specified
Using the Flash lube would it be required to be added everytime i pour petrol or is it after a certain amount of ks.
everytime you pour petrol or i think you can get an auto feed setup. i remmeber a mates C20 pickup had some moreys upper cylinder lube setup under the bonnet but i never payed much atention. |
Havent you learnt anything from that guy that gives sermons at church?...Captain whats his name. |
whats the go with the best premium unleaded is it BP ultimate 98 ?
this is what almost everybody has stated to me in the past ?
I have a device that is attached to the fuel line that the fuel passs through before it gets to the motor and it apparently has a "lead" core or something like that. It is guaranteed for 250,000 klms and no more putting additive in the fuel tank everytime I fill up.
From memory it cost me about $200 fitted?
I have been using BPs 98 octane unleaded for the last few years and find that I am getting considerably more ks out of a tank of fuel than regular unleaded. The extra ks far outway the extra cost per litre.
Cheers, Allan
I always use BP 98 with flashlube just buy a big bottle for home base then the little 50ml squirt bottle of flash lube and refill it from the big one. Easy to carry around in the glove box or console. I have seen some of the self drip feeds and they can look veeery agricultural.
i use any fuel thats cheap and dont use any lead additive and dont really care about the valves etc as it takes around 100,000 k plus to affect them anyway..by that time ive saved enough money from not spending money on additives to get my heads done and go on a european holiday....just a quick edit to add that if a car i own pings then i use a better quality fuel.. going to church makes you no more a christian than standing in a garage makes you a car... www.classicozwreck.com.auEdited by user Friday, 5 June 2009 9:21:21 PM(UTC)
| Reason: Not specified |
You have been a member since:: 1/03/2005(UTC) Posts: 6,164
What he said ^^^^.
Dr Terry |
quote: Originally posted by Dr Terry
What he said ^^^^.
legendary status granted to the DOC for this queens birthday weekend
also granted legendary status, and a QBE for such wise and "common sense" comments in here
just bring my QBE with a serve of mint gelati when you visit please frank.... going to church makes you no more a christian than standing in a garage makes you a car... www.classicozwreck.com.au |
its on ice already mate.... and the QBE, well, ill just strap it to my g-string for same measure..
I have just always put low grade unleaded in all my cars. EH, VW etc. No upper cyl lubricant.The EH Limo does have inserts in the head. I use premium in my motorbike. http://www.ehlimo.com.au/ |
