#1 Posted : Sunday, 7 August 2005 7:54:50 PM(UTC)
I'm tim, i'm not going to pretend i'm any good with cars because i'm not.
Since acquiring this car the engine noise has changed from what you would normally hear in a small car to a slightly higher pitched noise that seems to react more when the clutch is in and i am changing gears.
I am all out of ideas and would like any help that can be given to me, if needed i can also supply for information to you, if you are of course willing to help.
thanks.
wayne Offline
#2 Posted : Sunday, 7 August 2005 9:45:25 PM(UTC)
wayne
is this noise in the motor or the clutch? if in the clutch it may be the thrust race?
First
On
Race
Day
Munromad2004 Offline
#3 Posted : Sunday, 7 August 2005 9:58:23 PM(UTC)
Munromad2004
I had a similar problem with a very persistent and very annoying high pitched whine every time I drove my car. It seemed to increase proportinally to acceleration and when I backed off the accelerator the noise usually abated to a more acceptable level.
#4 Posted : Monday, 8 August 2005 7:13:43 PM(UTC)
it may be the clutch yes....
the engine noise when i put the car into neutral is not a normal sound, it's slightly higher then a normal engine noise and, well it's hard to explain but it isn't a normal sound... anymore help?
