3 Pages123>
#1 Posted : Sunday, 7 August 2005 9:09:29 PM(UTC)
Hi Guys,
Im hoping you can help me decipher the ID plates on my HK
Body ID RHS:
BODY HK369A-18013B
TRIM 1258-18F
PAINT 568-3912
INSERT (blank)
TOP 568-10845
Long plate on top LHS:
80369KH121278
Firewall Stamping:
HK19345B
Engine #:
186p127880
It's a HK Kingswood sedan, original(?) off white paint with white roof, tan vinyl trim, 186 + powerglide coloumn shift. I thought at least some of these codes were supposed to match or is my car a bitsa, it certainly looks like it's unmodified!
The only code I can decipher is the Long Plate LHS as this info is in my HK shop manual. This may sound daft but I can't figure what year model it is 68 or 69, the dec 2004 club rego sticker has no model info other than 'holden sedan' and i have no old rego papers.
Going by the the vehicle serial/sequence number 21278 may mean it's a later 69 build?
My 1970 HT ute has an extra compliance plate attached which shows more date (5/70 build) info but the HK doesn't have this...
Thanks Guys.
Munromad2004 Offline
#2 Posted : Sunday, 7 August 2005 10:25:59 PM(UTC)
Munromad2004
80369KH121278 deciphers as
8: Holden
03: Kingswood (or Monaro) 6 cylinder
69: Sedan
K: HK
H1: Manufactured at Acacia Ridge (Brisbane)
The serial number 21278 means it was the 21,278th vehicle (not just HKs) built at Accacia ridge.
#3 Posted : Sunday, 7 August 2005 10:25:59 PM(UTC)
Munromad2004
8: Holden
69: Sedan
K: HK
The serial number 21278 means it was the 21,278th vehicle (not just HK's) built at Accacia ridge.
#4 Posted : Monday, 8 August 2005 1:42:23 AM(UTC)
The A after HK369 means AUTO on an Acacia Ridge vehicle. The Dulon code after TOP is for Ermine white, meaning it had a white roof. Youve made a mistake with the paint code, if the body Dulon code of 568-3912 is correct as 1258 is not Kingston cream (it i
#5 Posted : Monday, 8 August 2005 1:42:23 AM(UTC)
The A after HK369 means AUTO on an Acacia Ridge vehicle. The Dulon code after TOP is for Ermine white, meaning it had a white roof. You've made a mistake with the paint code, if the body Dulon code of 568-3912 is correct as 1258 is not Kingston cream (it
#6 Posted : Monday, 8 August 2005 2:03:45 AM(UTC)
I double checked and all those codes are correct
+ what is the cars year of manufacture?
#7 Posted : Monday, 8 August 2005 2:03:45 AM(UTC)
+ what is the car's year of manufacture?
#8 Posted : Monday, 8 August 2005 2:07:26 AM(UTC)
+ the trim is all light tan coloured vinyl with vinyl flooring which fell apart...I am about to replace with carpet, no black interior other than the dash cluster.
#9 Posted : Monday, 8 August 2005 8:04:38 PM(UTC)
Ok. I will check at home again, but if the numbers are right then 1258 must be the paint code for a Kingston Cream body with Ermine white roof (yuk! what does the combo look like?). It looks like a 1969 or late 1968 build by the body number, but I'm not f
#10 Posted : Monday, 8 August 2005 8:04:38 PM(UTC)
Ok. I will check at home again, but if the numbers are right then 1258 must be the paint code for a Kingston Cream body with Ermine white roof (yuk! what does the combo look like?). It looks like a 1969 or late 1968 build by the body number, but Im not fu
#11 Posted : Monday, 8 August 2005 10:45:03 PM(UTC)
Munromad2004
I have seen HK Kingswoods with that colour combo ie off white (almost light tan) and white roofs. They don't look that bad but are not exactly an eye catching combination.
I thought the top code was Ermine White (at least that's what my list says) but
#12 Posted : Monday, 8 August 2005 10:45:03 PM(UTC)
Munromad2004
I have seen HK Kingswoods with that colour combo ie off white (almost light tan) and white roofs. They dont look that bad but are not exactly an eye catching combination.
I thought the top code was Ermine White (at least thats what my list says) but d
#13 Posted : Monday, 8 August 2005 10:54:02 PM(UTC)
I think you misread his post. White roof, tan vinyl trim.
#14 Posted : Tuesday, 9 August 2005 1:32:42 AM(UTC)
Munromad2004
Yep. Silly me. It all makes sense now.
Did we decide what colout the body was though? I only had a list of HK Monaro paint codes and it had 3912 as Kingston Creme and 10845 as Ermine White.
#15 Posted : Tuesday, 9 August 2005 3:26:56 AM(UTC)
The TRIM code is the problem. Forget the PAINT code, this is simply a Dulon code. The Holden paint code is the beginning of the TRIM code, ie 1258. This must be the combination of Kingston cream body, and Ermine white roof. I don't have a list of these co
#16 Posted : Tuesday, 9 August 2005 3:26:56 AM(UTC)
The TRIM code is the problem. Forget the PAINT code, this is simply a Dulon code. The Holden paint code is the beginning of the TRIM code, ie 1258. This must be the combination of Kingston cream body, and Ermine white roof. I dont have a list of these com
#17 Posted : Tuesday, 9 August 2005 6:12:29 AM(UTC)
18F is Buckskin Beige vinyl in a Kingswood design.
#18 Posted : Tuesday, 9 August 2005 7:50:48 AM(UTC)
you'd be right Byron it looks like that colour
i've photoshopped it so it's easier to read, this is the id plate
and can anyone tell the build date, or know where to look to f
Edited by user Tuesday, 9 August 2005 8:01:39 AM(UTC)  | Reason: Not specified
#19 Posted : Tuesday, 9 August 2005 7:50:48 AM(UTC)
youd be right Byron it looks like that colour
ive photoshopped it so its easier to read, this is the id plate
and can anyone tell the build date, or know where to look to find
#20 Posted : Wednesday, 10 August 2005 5:50:45 PM(UTC)
Late November 1968. You steering box and steering column should have codes on them (if original) with something like **L8 with the ** being the day of the month, L being november and 8 being 1968.
Guest (20)
3 Pages123>
This page was generated in 0.082 seconds.
