#1 Posted : Monday, 27 December 2004 4:04:29 AM(UTC)
Hey all, ive been having a weird problem with my XC 4.1. It has an intermittent problem with really rough idling and backfiring under decelleration/no load. It is fine under hard acceleration tho. I have tried absolutely everything i can think of to fix this problem. Plug leads, new fuel pump, new needle and seat valve, checked carbie bowl level, cleaned out idle mixture screw and adjusted, replaced points/fixed timing.. everything seems perfect. The problem will be terrible for a few days and then come good again for a while. can't work this one out but its bugging the hell outta me. any other ideas on what i can do would be GREATLY appreciated. thanks heaps guys
Brett
#2 Posted : Monday, 27 December 2004 8:44:03 AM(UTC)
Hi Brett, What is the intake manifold gasket like?
#3 Posted : Monday, 27 December 2004 8:44:26 AM(UTC)
#4 Posted : Monday, 27 December 2004 12:47:19 PM(UTC)
Hi Brett,
I had similiar trouble with my XC and it was caused by me running my petrol tank absolutely dry before re-filling her. This caused sediment to be picked up from the petrol tank and it blocked the inline petrol filter from the tank to the f
#5 Posted : Tuesday, 28 December 2004 2:42:35 AM(UTC)
No idea, probably never been repalaced tho... could that cause probs?
#6 Posted : Tuesday, 28 December 2004 3:53:31 AM(UTC)
It's a long shot but it sounds like you've tried all the usual causes. I would normally expect a leaking manifold gasket to be a problem under acceleration as well, anyway it's just a suggestion.
#7 Posted : Wednesday, 29 December 2004 12:07:07 PM(UTC)
Second that motion, intake manifold gasket is a great cause of vaccum leaks. While you are replacing that do yourself a favour and if you have stromberg pick up weber from an XE falcon, fantastic carbi's and well tuned should be worth about 20hp, NB throw
