#1 Posted : Friday, 12 August 2005 12:27:36 AM(UTC)
hello all i was just thinking on some ideas on a 202 prepolution build for my hq and was wondering if a 265 crank out of a hemi 6 could be made to fit into a 202 block and if so what would be the benifits i've heard of fitting a ford crank though
also if this could be done what options do i have for rods, pistons and cam
thanks in advance.
#2 Posted : Friday, 12 August 2005 6:47:22 PM(UTC)
265 won't fit - too long. A Ford 221 can be made to fit, but these need a cut and shut with an early red 6 rear flange. Pro-stroke in WA do them. Will cost you a lot though. You probably are heaps better of $ wise buying a wrecked VN for $500, and getting
#3 Posted : Friday, 12 August 2005 10:10:05 PM(UTC)
what if u were to cut and shut a 265 or 245 or even 215 crank ??
#4 Posted : Saturday, 13 August 2005 9:39:10 AM(UTC)
The bore centres are too different for the Chrysler cranks to fit. The Ford motors' bore centres are the same (or very, very close) the the Holden ones.
Cheers...Dave
#5 Posted : Monday, 15 August 2005 11:09:27 PM(UTC)
ok cool thanks well how about a 250 ford crank out of a iron crank has anyone done this type of thing before?
#6 Posted : Tuesday, 16 August 2005 2:46:57 AM(UTC)
my mate used a ford 250 crank in his.
worked quite well too.
it now has a CRS blower kit also.
pretty mean HR sedan now!!
DO NOT WRITE BELOW THIS LINE
