Anthony333 Offline
#1 Posted : Thursday, 18 June 2009 6:11:34 AM(UTC)
Anthony333
Hi all,
I need to drill out some spot welds on my HG Van to do a trans tunnel modification... just wondering what size bit to use for the welds... Should i just use a bit the same as the spot welds, or should i use something slightly larger to remove the heated , old metal ?
Going to put in a Turbo 400...
Cheers for any advice here.
Ant
gmholdman Offline
#2 Posted : Thursday, 18 June 2009 6:37:38 AM(UTC)
gmholdman
You can buy proper spot weld bits all sizes....makes life easy. AL.
Utility8 Offline
#3 Posted : Thursday, 18 June 2009 6:39:00 AM(UTC)
Utility8
There is a drill bit that you can buy to do this job. It has a small drill point in the middle & a cutter on the outer edge of the tool. As you drill into the spot weld, the outer edge cutter will cut a ring at the approx outer edge of the weld. It will not remove all the metal like a normal drill, so you have material to weld when refitting panel. Once done, you may need to persuade the metal apart. Should be able to get one from any reasonable tool/engineering suppliers. Enjoy.
Utility8
utility8
#4 Posted : Thursday, 18 June 2009 6:39:14 AM(UTC)
you can buy a spot weld drill from most body supply shops, use that if you are keen, or if you are like me, just use a 5" grinder with a 1mm cutting blade, or a plasma cutter, but then again im a drag racer, so it doesnt really matter how much we cut out of a car!
bigindian66 Offline
#5 Posted : Thursday, 18 June 2009 8:16:12 AM(UTC)
bigindian66
Bordo Industrial Tools have spotweld bit. Most commonly used is 8mm. You can buy them in 45 and 79mm long.
They are a HSS/Cobalt bit and are good quality.Try website
www.bordo.com.au
peter_flane Offline
#6 Posted : Thursday, 18 June 2009 9:37:08 AM(UTC)
peter_flane
Spot weld drill bits come in 6mm and 8mm. Buy a good quality cobalt one. They are used by most quality accident crash repairers.
http://www.ehlimo.com.au/
