bathurst72 Offline
#1 Posted : Friday, 19 June 2009 12:31:37 AM(UTC)
bathurst72
Hi, can anybody please tell me the year of my FJ Special Sedan from the only plate which is attached to the car.
FJ 225
Body # S14947
Trim # 111-393AB
Paint # 253-17300
Top Acc6
Just after the year as Iam trying to get personalised plates for the car.
thanks and cheers
steve
HJGTS Offline
#2 Posted : Saturday, 20 June 2009 6:41:01 AM(UTC)
HJGTS
The Chassis number on the sub frame should be able to tell you the year
gmholdman Offline
#3 Posted : Saturday, 20 June 2009 7:24:47 AM(UTC)
gmholdman
Steve, by your paint code(Mist Grey)it was only used in 1954. To double check, see if your shockers are behind the rear axle, eg.between diff housing and rear of car. AL.
bathurst72 Offline
#4 Posted : Sunday, 21 June 2009 10:49:11 PM(UTC)
bathurst72
Hi, thanks for the replys. The shockies seem to be mounted to the front of the diff. There is no diff in the car and the top shockie mount is infront of the back seat supports to the floor.
The original colour is a two tone green, not grey. It looks factory.
The chassis number is 6-8240-S.
Anymore help would be appreciated.
thanks and cheers
Steve
LHQ-253 Offline
#5 Posted : Sunday, 21 June 2009 11:49:51 PM(UTC)
LHQ-253
Hi Steve,
The 6 in the chassis number means 1956.
Andy.
bathurst72 Offline
#6 Posted : Monday, 22 June 2009 12:00:00 AM(UTC)
bathurst72
Hi Andy, thanks and cheers
Steve
gmholdman Offline
#7 Posted : Monday, 22 June 2009 7:20:42 AM(UTC)
gmholdman
Steve, the paint number you posted is definately "Mist Grey", maybe incorrect body tag has been fitted??? AL.
FJ003 Offline
#8 Posted : Sunday, 7 September 2014 9:12:02 PM(UTC)
FJ003
Hi i am seeking help i have an FJ Ute the Chassis number reads 514888B can someone help me decipher this. I Know that B stands for Brisbane.
gmholdman Offline
#9 Posted : Monday, 8 September 2014 8:04:45 AM(UTC)
gmholdman
Maurice, the digit 5 is for 1955 and is the 13888th assembled at Brisbane ( YES, the 13888th not 14888th, the 1st number started at 1000) AL.
FJ003 Offline
#10 Posted : Tuesday, 9 September 2014 1:43:10 AM(UTC)
FJ003
Thanks very much for that can you help with the otherId
Trim 54275
Paint 25317340
Body B175
#11 Posted : Tuesday, 9 September 2014 1:55:04 AM(UTC)
AFAIK they begin at 1001, not 1000.
peter_flane Offline
#12 Posted : Tuesday, 9 September 2014 6:21:03 AM(UTC)
peter_flane
Engine numbers and chassis numbers start at 1001. Body numbers start at 1
gmholdman Offline
#13 Posted : Friday, 12 September 2014 7:16:40 AM(UTC)
gmholdman
Maurice, 54275 is Mountain Blue PVC
253 17340 Mosman Blue. These combinations are for 1954 so the chassis(sub-frame) number should start with "4" so may have had the sub-frame changed at some stage??
