Fastlane
Holden Forums
Holden General Discussion
HZ powersteering can you use a commodore pump?
Hi guys
Just wondering if a commodore pump can be used with a standard HZ power steeering box. I have a VP 5L in an HJ ute - I am guessing the hydraulics would have to be custom made, but the pump would be a lot cheaper and probably work more efficiently...
Any thoughts on this?
Thanks: 1 times Was thanked: 635 time(s) in 597 post(s)
Should work fine. VB-VL 5.0L Commodores used the same pump as a HZ. |
Hi richo2.
To be 100% correct you should use the pump off a car that has 'varitronic' steering (Calais, Statesman, Caprice etc) as all VL onwards Commodores with normal power steering use a 'droop valve', but I've see guys use these pumps with no probl |
Me again, I haven't bought anything yet, but it seems to be cheaper trying to get the HZ box and any commodore pump. Not sure if the 'droop valve' is far insuperior than varitronic pumps, if the 'droop valve' style pumps make more noise, I'll go for one o
I put a VT 5L one on a VH 6 - with the droop valve, and it was no hassles with the standard power rack & pinion, so as long as you can get hoses to fit it, go for it.
I changed the fitting in the rear of the pump to suit the VH hose, and the only other
Fastlane
Holden Forums
