greenhj Offline
#1 Posted : Sunday, 21 June 2009 6:32:45 AM(UTC)
greenhj
it wont crank the engine over yet tests fine on the bench using the same battery and jumper leads extending the wiring (70 sq. mm flex)
battery is fully charged.
its a cae high torque deal 3.5hp and its been fine for 4yrs.
Its not just a matter of replacing it, i would like to know why and what is causing it before parting with another $350.
Can an auto elec load test it?
11.38@117
Edited by user Sunday, 21 June 2009 6:34:08 AM(UTC)  | Reason: Not specified
the Blue Light Offline
#2 Posted : Sunday, 21 June 2009 6:48:36 AM(UTC)
the Blue Light
Maybe some of the windings have shorted, but there is still enough there to spin it under no load? Its not producing the torque right? Its not something like the solenoid not engaging?
greenhj Offline
#3 Posted : Sunday, 21 June 2009 6:56:16 AM(UTC)
greenhj
nup, solenoid is engaging fine, i rigged up a remote switch so i could lie under the car and crank it over to see whats (not) going on.
11.38@117
Casper Offline
#4 Posted : Sunday, 21 June 2009 10:28:52 AM(UTC)
Casper
Bad earth to engine block?
Try running one of your jumper leads fron the batt- to the alternator bracket or similar.
#5 Posted : Monday, 22 June 2009 1:47:40 AM(UTC)
pull one from a car that u know works,then u can eliminate car earth versus starter...jim
Jim in adelaide
greenhj Offline
#6 Posted : Monday, 22 June 2009 7:45:37 AM(UTC)
greenhj
it was the battery, problem solvered...
11.38@117
HQforme Offline
#7 Posted : Monday, 22 June 2009 9:56:24 AM(UTC)
HQforme
Indeed. Starters are the biggest load on a battery. Ive had it a few times where the decent reading on the multi-meter doesnt translate to full cranking juice. Glad you got it sorted for no expense.
"Silly modern cars"
