#1 Posted : Tuesday, 16 August 2005 8:56:59 PM(UTC)
Gents, how can i id this gearbox? and are there other requirements to fit this to a 202 in the hq? eg cross member & driveshaft length. And is there anything i should look out for on this box b4 i buy it.
#2 Posted : Tuesday, 16 August 2005 9:33:15 PM(UTC)
It should bolt up, but note that the blue and black motors use a bigger clutch plate and hence the flywheel has the pressure plate bolts further out to suit. This means you might have to use the VC-VK flywheel, unless the gearbox spline is the same as an
#3 Posted : Wednesday, 17 August 2005 4:50:12 PM(UTC)
i'd obviously need to replace my bench seat for sum buckets? as i've got column shift 3spd and don't wanna lose the seating.
#4 Posted : Wednesday, 17 August 2005 8:07:03 PM(UTC)
Your best option then is an M22 aussie 4-speed with HQ-WB bench seat shifter, and stick a 3.08 or 2.78 diff in it. Your 4th gear will be basically the same overall ratio as 5th in a 5-speed, and 1st will be about the same as an M20 with a 3.55 diff.
This page was generated in 0.109 seconds.
