YetAnotherForum.NET Help
fitzsi Offline
#1 Posted : Monday, 22 June 2009 11:41:51 PM(UTC)
fitzsi
Can anyone tell me if you can change the outer gears in a banjo diff so you can use say coarse spline axles in an original fine spline diff ( 3.55 RATIO ) TO A COARSE SPLINE DIFF ( 2.78 RATIO )
#2 Posted : Monday, 22 June 2009 11:46:59 PM(UTC)
Yes. Those sun gears are the difference between coarse and fine spline centres. Not sure how its done though as I have never done it myself. From memory you have to change the gear and the cone on each side too if its an LSD.
fitzsi Offline
#3 Posted : Monday, 22 June 2009 11:58:01 PM(UTC)
fitzsi
Just looking to pic one up for the sons Torana but having probs picking up a coarse spline to suit his axles
#4 Posted : Tuesday, 23 June 2009 12:42:13 AM(UTC)
What model Torana? If its an LH/LX just use some fine spline axles. They are easy to find.
#5 Posted : Tuesday, 23 June 2009 1:22:07 AM(UTC)
AFAIK most LX have fine spline axles, but wouldnt an HQ diff be more readily available. All 6-cyl HQs had coarse spline axles & they would be easier to find than Toranas.
Dr Terry.
