HI HAS ANYONE DONE A 308 INJ INTO HG.DO I HAVE TO GET IT ENGINERED I HAVE BEEN TOLD IF I USE A RED BLOCK IT DOESNT NEED TO BE ENGINERED ALSO DO I HAVE TO USE CAT CONVERTERS THANKS
STOP YELLING,YOUR HURTING MY EARS!!!
thanks.
P.
I forgot to send you that file. Ill try to do so soon. If you use a pre HJ block you need nothing, but youll probably get away with any red block except VT or ZT prefix. An NT would be the best.
How about 1985 Corvette TPI onto a HK 307?
Best idea with these is to use a VN harness, sensors and ECU. Just have to get the VN dizzy modified to fit the SBC.
Thanking you, food for thought.
thaks any help would b great
