tripple webers Offline
#1 Posted : Friday, 26 June 2009 6:21:18 AM(UTC)
tripple webers
Hi i have a HQ 1 tonner tailshaft which has the big Unis, is there a uni available so i can fit it to a standard HQ V8 Diff yoke which has the smaller cup size.
#2 Posted : Friday, 26 June 2009 6:39:44 AM(UTC)
Yes. Its got 1.125" cups on one axis and 1" on the other. Ask at an auto parts shop. Rares should have them.
#3 Posted : Friday, 26 June 2009 6:42:22 AM(UTC)
tripple webers
thankyou i will give them ago. cheers
D. A. Barnes Offline
#4 Posted : Saturday, 27 June 2009 10:32:52 PM(UTC)
D. A. Barnes
This shaft is obviously not in a 1 Tonner at present? If you had it shortened, did they use the same end? Might have been easier to get a regular V8 end fitted when it was shortened and that way the regular universal could be used. If you are looking for a universal then it sounds like the shaft hasnt been balanced yet. Didnt that get done when it was shortened? GTS 350s use the same big yokes/universals.
#5 Posted : Saturday, 27 June 2009 11:48:34 PM(UTC)
maybe hes just changed the diff in his tonner to a ute/van one?
#6 Posted : Sunday, 28 June 2009 3:52:57 AM(UTC)
tripple webers
Tailsaft is going into a Mitsubishi Triton fitted with a VR V6, needed the length of the 1 tonner to replace the original 2 piece shaft. Diff we are using is out of a VK Commodore V8.
#7 Posted : Sunday, 28 June 2009 5:34:52 AM(UTC)
the ute wouldnt be yellow would it?
#8 Posted : Sunday, 28 June 2009 8:44:41 AM(UTC)
tripple webers
No its white
