#1 Posted : Thursday, 18 August 2005 4:13:04 AM(UTC)
My Vk Calais speedo is always all over the place and i was told today that the V8 Calais didnt come with Turbo 350 boxes although this is what mine has. Can anybody tell me how to fix this?
#2 Posted : Thursday, 18 August 2005 5:18:03 AM(UTC)
Probably the speedo cable. Yes the VK still has a cable - of sorts!
The speedo is fed it's electronic signal from the speed sensor fitted to the cruise control transducer - mounted on the RH strut tower below the brake master cylinder. The transducer
#3 Posted : Thursday, 18 August 2005 9:28:10 AM(UTC)
Ill give it a go Commodorenut. Cant thank you enough for your help with my posts. Hope i can help you some day as much as you have helped me!
#4 Posted : Thursday, 18 August 2005 6:49:01 PM(UTC)
HZ and VB as well. All V or W series Holden (W includes HZ and WB) between about mid 1979 and late 1982 had a TH350 if originally fitted with a 308 and auto. Look for M38 on the body plate. I'm pretty sure the HZ never had the cruise control option though
