#1 Posted : Sunday, 28 June 2009 12:20:21 AM(UTC)
1/ what does this number mean, ive never noticed a number there before?
2/ how do you remove these things?
chassis is from a HQ p/van
vintageholden Offline
#2 Posted : Sunday, 28 June 2009 1:13:20 AM(UTC)
vintageholden
no idea of the number
but remove them with a grinder
#3 Posted : Sunday, 28 June 2009 3:12:59 AM(UTC)
"remove with grinder" can you buy replacements?
they are the only thing left on my chassis, and they need to be removed, so if theres no other suggestions then grinder it is then
#4 Posted : Sunday, 28 June 2009 7:05:01 AM(UTC)
vintageholden
i didnt know you wanted to replace them..........
grind them off and replace with new ones riveted on
#5 Posted : Sunday, 28 June 2009 7:12:06 AM(UTC)
yes i will need to replace them
chassis is about to get sandblasted and either re-painted or powder coated , not sure which way to go yet? depends on the cost really
how do these clips hold on, is it some sort of one way clip? i cant work out how to get them off without destroying them, and id rather not destroy them cause id have to buy new ones, and im a real tight arse
gtrpu Offline
#6 Posted : Sunday, 28 June 2009 7:35:21 AM(UTC)
gtrpu
Theres a pin that knocks into the clip and expands it inside the chassis....if you know what I mean. I dont know how to save the pin but to remove the clip just get a small punch and knock the pin thru from the top (it ends up inside the chassis)....if that makes sense. Rares sell new ones and theyre not that expensive.....or you can get them at Autopro/Repco etc.
#7 Posted : Monday, 29 June 2009 3:49:20 AM(UTC)
clips removed, thanks gtrpu, i knocked the pins through into the chassis, and the clips just pulled out, i then stuck my arm in the chassis and retrived the pins ,so i can re-use them
#8 Posted : Monday, 29 June 2009 3:50:12 AM(UTC)
#9 Posted : Monday, 29 June 2009 3:53:40 AM(UTC)
oh, and i was told today that the number is most likely a date code from when the chassis was built, number is 22B2 which would mean 22nd of feb 1972 which fits in with the build date of the car
so all mysterys solved
