what air cleaner would a 10/1973, 308 powered, HQ GTS/4 have factory fitted?, would it have the thermostat doovie on the snorkel or not? it is a factory trimatic & factory A/C too, if that makes any differance...
Kevin
HOLDEN The Great Way to Move |
no thermo fitted snorkell only
Kevin,
I'd have a guess and say the 73 series would not. Here is why.
The HJ engine manual (Oct74 onward) shows the thermo doovie. My Jun 74 253 has the heater adapter on the LH manifold, so it takes the hot air intake. I have the rocker cover breat
I have an august 73 sales booklet and the V8 engine pic has no thermo part on the snorkell cheers
Hi Guys.
This took a bit of research, but I have the definitive answer. Also it pays not to use sales brochures for info on mid-model upgrades. They are not always reliable.
According to a factory service bulletin I have, dated Sept '73, ADR27 was i |
Dr Terry,
Is this for the 308 only ? My Aug 73 253 does not have those mods. Would this be right? I'm the 2nd owner.
Cheers, John
Hi John.
The changes were done to all the Aussie engines around the same sime.
The bulletin only says 'introduced into production during August'.
To me that would mean that in August production there would be cars WITH & cars WITHOUT the extra ge |
Hi Dr Terry,
DER on ME !!! I just had a look !
The 1973 HQ has ...25, 26.
The 1974 HQ has ...25, 27, 28
For those that dont know: ADR 25 - anti-theft locking (LOL) ADR 26 - not/never used, hence missing on the 74 car ADR 27 - emission regs
MMMMM very interesting, My complience plate has ADR 25 & 26. so I take it mine had no thermostatically controlled vacuum flap on the snorkel, which is quite strange if that bulletin took affect in august 73, as before mentioned, mine was built on the 5th |
Hi Kevin.
The other clue would be to see if the carby has the tamper proof idle screws. This is only true for the 6 cyl & 253 V8s though.
Dr Terry |
