#1 Posted : Monday, 1 December 2003 7:53:59 PM(UTC)
Does anyone know of a satisfactory tool to reach the top fuel pump bolt on a Ford Cleveland (XC) with the air conditoining and power steering installed????? I have tried everything I have in my tool box.
#2 Posted : Tuesday, 2 December 2003 12:55:30 AM(UTC)
I think I am going to have to remove the power steering pump, grrrrrrrrr.
#3 Posted : Wednesday, 3 December 2003 7:56:30 AM(UTC)
Bill,
don't remove the power steer pump, just loosen it a bit and slide it across. That should give you enough room. Open ender spanner is probably the best tool to use.
#4 Posted : Thursday, 4 December 2003 1:51:15 AM(UTC)
Done, thanks Paul. Only I dont have much clearance now between the power steering belt and the bottom radiator hose. Because the high volume (Holley) pump has a mush larger diameter than the stock pump, its almost touching. I guess they make all of the af
#5 Posted : Thursday, 4 December 2003 7:37:21 PM(UTC)
Are you trying from underneath? Or from the top? You need to go from underneath.
Brenden
