#1 Posted : Tuesday, 30 August 2005 10:26:49 PM(UTC)
I recently a purchased a supercharged V6 motor from the wreckers, with the intention of putting it in my VS commodore ute. I now find that the heads are completly stuffed obviously the motor had a flogging in its its previous life.
Are the heads off a standard V6 the same as the Supercharged ones?
Hope You can help
Yours Sincerely
G. McCorriston
#2 Posted : Tuesday, 30 August 2005 10:30:03 PM(UTC)
Nope - the super6 heads have provision for the injectors at the top of the inlet ports because they aren't in the manifold like a naturally aspirated one.
#3 Posted : Wednesday, 31 August 2005 9:11:54 PM(UTC)
Thanks that helps some, the only differnce I thought was that may be different size valves and stronger valve springs.
