kanks Offline
#1 Posted : Tuesday, 28 July 2009 7:02:37 PM(UTC)
kanks
has anyone had any success wih one of those cheap 300$ at racing ones or do i have to go a harrop 800$ one i only have a small budjet or am i wasting mt time thanks
#2 Posted : Tuesday, 28 July 2009 7:30:30 PM(UTC)
If you are talking about a manifold for an EFI 304 (ie not a VK-VL carbied 304) try one of the Hardiman/Redline manifolds. I used a single plane Redline (Highwinder?) on a standard VP engine and it was a dog - the combo of the big heads and single plane were not great especially in a big heavy HZ 4x4 auto. That was on petrol or LPG. It was a much better street engine with standard red engine with dual plane manifold. So if it were me Id be looking to a Redline dual plane, unless you are building a 350 stroker but even then Id still use a dual plane for a street car.
greenhj Offline
#3 Posted : Tuesday, 28 July 2009 9:41:51 PM(UTC)
greenhj
Was thanked: 15 time(s) in 13 post(s)
you are wasting your time with cheap ebay manifolds, Dont buy one...
As far as the redline single goes, i have one on my 350 +0.030 holden engine, it runs 11.3 in a 1560kg car, and i can happily sit in traffic, or lope along at 1800rpm.
0 to 60mph in under 4 seconds so it cant be too bad...
On a 304 however id probably look for a decent dual plane manifold and 600cfm holley unless you are looking for performance at the expense of driveability.
11.38@117
kanks Offline
#4 Posted : Tuesday, 28 July 2009 11:10:18 PM(UTC)
kanks
thanks looks like it is a harrop then and heaps more overtime
#5 Posted : Wednesday, 29 July 2009 3:04:07 AM(UTC)
Do they make a dual plane one though?
greenhj Offline
#6 Posted : Wednesday, 29 July 2009 3:20:50 AM(UTC)
greenhj
yep, they do.
although id wager the torquepower dual is probably better.
11.38@117
#7 Posted : Wednesday, 29 July 2009 5:05:41 AM(UTC)
This is the one I used, and as Greenhj says it would probably be OK on a 350.
http://www.redlineauto.c...12-116?category=PBPGTNQM
HQforme Offline
#8 Posted : Wednesday, 29 July 2009 6:29:49 AM(UTC)
HQforme
You always get what you pay for. People are probably guilty of thinking a manifold is a simple casting and that a cheap one would work fine, but its not the case if you want it to work to its potential.
Like previously posted, a dual plane will be a much better option in a street motor. Redline are very reputable, as are Torquepower.
"Silly modern cars"
