#1 Posted : Saturday, 3 September 2005 7:29:51 AM(UTC)
my vr commodore keeps stopping, when you wind it over it sounds like it is firing on the wrong cylinder.I was told it was the crank angle sensor. I replaced it and it seems to be running much better. I cleared the fault code and I still have code 12 come up followed by code 48. I have removed the engine fuse for 1 min, code 12 will flash untill the car is stared. Is this normal?
Craig
#2 Posted : Saturday, 3 September 2005 9:16:58 PM(UTC)
Hi Craig, is it just the 12 (system ok) code coming up know? 48 is for the crank sensor, if you have replaced the sensor and reset the comp you should only have the 12 code coming up. Here is a link to a full list of code ID. http://www.justcommodores.com
#3 Posted : Sunday, 4 September 2005 1:48:31 AM(UTC)
Hello All
Read with interest the codes. Does one need a special instrument to read the codes from the car? Where is the computer and how does one access it?
Regards
gts_hg
#4 Posted : Sunday, 4 September 2005 3:07:00 AM(UTC)
The Gregory's manuals cover most of it. Just find the diagnosis plug and put a peice of wire across the 2 correct pins to get it to test and show any fault via the eng light flashing to show what code/faults. Below is a good link to tech site,
http://www
#5 Posted : Sunday, 4 September 2005 5:43:01 AM(UTC)
thanks for the help, I cleared it again and I am still getting 48 once the engine is started. in the gregorys manual it said to check a couple of terminals at the computer, if the voltage is ok replace the computer. anyone know what one is worth if it com
#6 Posted : Friday, 11 November 2005 6:38:36 AM(UTC)
Thanks for the replies, even though I am very late checking the forum.
Regards
gts_hg
