lgs Offline
#1 Posted : Thursday, 27 August 2009 3:10:28 AM(UTC)
lgs
The Hood cable has snapped and would love to know if theres an easy way to release the bonnet,can reach the leaver but thats no good until catch is released, I have taken off bumber bar and stone gaurd to allow access but can not get to cable, it has snapped near catch
any suggestions _ desperate
bold
bold
#2 Posted : Thursday, 27 August 2009 3:34:32 AM(UTC)
you have to pull the catch first so the bonnet pops up,then the lever.2 people would be better,use big plyers or a screw driver,should work..jim
Jim in adelaide
#3 Posted : Thursday, 27 August 2009 5:07:59 AM(UTC)
its a easy fix if you know what to look for, basicly all you need to do is get a flat thin peice of steel and put it through the gap between the grill and the bonnet and push the latch accross, the perfect tool is a door handle removing tool, but any thin flat peice of steel would do
cheers dave
80569K Offline
#4 Posted : Thursday, 27 August 2009 5:38:34 AM(UTC)
80569K
A 12" steel rule is good too, round end in the palm of your hand. Put a bit of downwards pressure on the bonnet when you slide the latch open with the rule.
#5 Posted : Thursday, 27 August 2009 5:41:27 AM(UTC)
ahh yes, a bit of downward pressure would make it eaiser too
got your email lgs, lets us know how you go
