#1 Posted : Saturday, 10 September 2005 2:31:17 AM(UTC)
hi guys, iam getting ready too begin the painting process for my 1 tonner, was wondering what type of sand i need to use to sandblast some of the parts.Ive goot all the equipment but i need to know what sand too use
cheers guys
#2 Posted : Saturday, 10 September 2005 3:41:03 AM(UTC)
Talk to a Sandblaster. They use Ilmenite, Rhyolite? and others and may be able to sell you some. You MUST be careful on flat surfaces though.
#3 Posted : Saturday, 10 September 2005 7:04:03 AM(UTC)
...and never sandblast both sides of the same panel, it will warp.
try plugging up any 'black' holes with rags or whatever or the sand may never come out again, at least until it rusts it's way through the metal
[IMG]http://i11.photobucket.com/albums/
edelbrock1 Offline
#4 Posted : Saturday, 10 September 2005 7:37:27 AM(UTC)
edelbrock1
NEVER EVER use river/beach sand.. if you breath in the dust it causes a lung disease, similar to what the guys that where exposed to asbestos got.
Most sand blasters use "Garnet" in their blasters. get a bag of that and see how you go.
treborsenrab Offline
#5 Posted : Saturday, 10 September 2005 7:25:10 PM(UTC)
treborsenrab
sandblast on an angle and definitely not straight at the part if its a panel, so ive been told.prevents pressure{denting}damage
be an innovator, not a imitator
#6 Posted : Wednesday, 14 September 2005 8:53:51 PM(UTC)
Thanks for all the info guys, i will give all the suggestions a go
#7 Posted : Thursday, 6 October 2005 10:44:43 AM(UTC)
I wouldnt sand blast any of your pannels. Take everything to an industrial paint stripper and get it caustic dipped. I found a place that hot dip galvanises stuff and they had a big bath and it was all alot cheaper than sandblasting. Yr panels will warp I
#8 Posted : Thursday, 6 October 2005 11:00:49 AM(UTC)
If you only run at 100 psi or so and don't get close to the work its ok, if the paint is loose/flaky it comes off easily and what doesn't come off easily remove by sanding.or just leave and primer over, if it's that stuck on it won't be a problem in futu
#9 Posted : Friday, 7 October 2005 3:25:33 AM(UTC)
Just to repeat be carefull with pressure and dont stay in one
spot to long. I ruined a good hz bonnet going hard on the underside
between the bracing! *#@*!
cheers chris
#10 Posted : Friday, 7 October 2005 9:51:04 PM(UTC)
I once read in a Practical Classics magazine that baking soda works really well as it does not harm the metal at all. Apparently it sort of explodes on impact which removes the paint. I have not tried it yet but I do intend on trying it.
Jim...
