Michael_4 Offline
#1 Posted : Tuesday, 1 September 2009 1:51:30 AM(UTC)
Michael_4
Gday guys,
I have a 1974 HQ monnaro sedan and from when i take off it has a constant sssssssssshhhhhhhhhhhhh noise coming from the rear...??? Its not really loud but loud enough to know its there. Anyone have any idea what this could be. Its not a build up after i take off but the noise is instant fom take off.
Any suggestions...???
Michael.
#2 Posted : Tuesday, 1 September 2009 3:37:16 AM(UTC)
buggered door seal or door not shut properly? could be road noise or air coming in
Davegtr202 Offline
#3 Posted : Tuesday, 1 September 2009 4:15:29 AM(UTC)
Davegtr202
JACK CAR UP AND SPIN THE WHEELS IT MAY BE A WHEEL BEARING AND PUT HEAD CLOSE TO LISTEN
hazzard county Offline
#4 Posted : Tuesday, 1 September 2009 5:02:04 AM(UTC)
hazzard county
when is the last time you saw the wife?
Edited by user Tuesday, 1 September 2009 7:29:39 AM(UTC)  | Reason: Not specified
#5 Posted : Tuesday, 1 September 2009 5:49:48 AM(UTC)
haha, i was going to suggest that but id thought id be nice
Mr Void Offline
#6 Posted : Tuesday, 1 September 2009 6:47:29 PM(UTC)
Mr Void
Snake around the diff?
Remote mount turbo?
Tyre scrubbing on a guard?
Some chump stuck something up your exhaust pipe?
Bailey channel stuffed in the rear window (or any of the other seals as suggested above)?
Branch caught under the car rubbing on the ground or driveshaft?
Brake shoe adjusted wrong?
___________________
Why are you reading this, you should be looking up there^^
___________________
Michael_4 Offline
#7 Posted : Tuesday, 1 September 2009 10:35:52 PM(UTC)
Michael_4
LOL i know its not the wife cos i use the car to get away for awhile.
Thanks ill check all these out.
#8 Posted : Tuesday, 1 September 2009 11:14:06 PM(UTC)
I had a sound like that once and it turned out to be a small rock caught between one of my rear discs and the caliper.
Maybe you have something floating around in a rear drum such as a spring come adrift.
As said jacking the car up and turning the wheels should tell you which side to pull apart.
If at first you dont succeed then skydiving is not for you.
Mr Void Offline
#9 Posted : Tuesday, 1 September 2009 11:33:59 PM(UTC)
Mr Void
If it was the wife it would probably be more of a whine than a ssshhhh... well, if it were mine it would
; p
___________________
___________________
Clawd Offline
#10 Posted : Sunday, 6 September 2009 6:17:06 PM(UTC)
Clawd
Diff bearings will give you this sssshhhhh sound.
Clawd
HG Monaros for ever!
