#1 Posted : Sunday, 11 September 2005 9:00:52 PM(UTC)
Hello all,
I have a 2001 AUII Fairlane Ghia V8 and under the current situation with petrol prices around $1.40/L am thinking of converting to gas. Does anyone know of any problems if I do this, will I lose much power, will it damage the engine. I also read somewhere that it affects the traction control.
#2 Posted : Sunday, 11 September 2005 11:28:21 PM(UTC)
I don't know for sure but based on other conversions I think the following would be true;
1. Run straight gas setup for optimum performance / efficiency.
2. Have computer remapped to match timing and combustion characteristics of gas. (you should not l
Edited by user Sunday, 11 September 2005 11:29:12 PM(UTC)  | Reason: Not specified
#3 Posted : Monday, 12 September 2005 8:49:10 AM(UTC)
Thanks for the info. The traction control bit was out of the manual, that why I was confused, I couldnt see the relationship either.
#4 Posted : Saturday, 17 September 2005 10:29:26 PM(UTC)
The traction control issue is actually true.
When traction is lost, TC works in various ways - killing timing (to reduce torque), cutting fuel (via some or all of the injectors), or even applying brakes on various wheels individually (using the ABS).
#5 Posted : Sunday, 18 September 2005 6:05:31 PM(UTC)
Thankyou, now Im starting to understand.
#6 Posted : Monday, 19 September 2005 6:10:03 PM(UTC)
aaah you learn something new everyday :)
Would same be true if using liqid phase lpg injection as this way gas is injected as liquid same as fuel??
Edited by user Monday, 19 September 2005 6:12:26 PM(UTC)  | Reason: Not specified
