Thanks: 1 times Was thanked: 243 time(s) in 217 post(s)
quote: Originally posted by shifty350
Hello Mark,
The details you have posted are correct. This component of the identification does not contain a W character in the 14 digit number. The driveline details are also correct (G80 indicating a limited slip diff.). This vehicle is an HJ GTS sedan assembled at the New Zealand plant from CKD kits supplied from the mainland. There should also be a plate with a 17 digit ISOVIN identification on the vehicle but these are often removed for one reason or another.
Hope this is of use.
Hi Ben Are you saying that NZ built Holdens of this era have a 17-digit ISOVIN in addition to the 14-digit item mentioned. Dr Terry |
Joined: 30/04/2005(UTC) Posts: 484  ![New Zealand New Zealand]() Was thanked: 16 time(s) in 15 post(s)
yes we have best cheese/wine / holdens , here in the south island ! |
life is good in "Wine & Holden Marlborough " |
Dont forget the best beer, nice looking girls and minimal Aucklanders! Edited by user Thursday, 1 October 2009 2:28:13 AM(UTC)
| Reason: Not specified
quote: Originally posted by Dr Terry
Hi Ben Are you saying that NZ built Holdens of this era have a 17-digit ISOVIN in addition to the 14-digit item mentioned. Dr Terry [/quote] Hello Dr Terry, Id re-phrase the "NZ built" bit to New Zealand delivered, but yes, the number starts with 7A8 and adheres to the GM protocol with various identifiers and a sequence number. I have seen these plates on all cars (imported and local assembled) since HQ series. I am lead to believe that this 17 digit number is the one used for registration but a New Zealand member on here would know a lot more in this regard as I have only a few dozen N.Z. cars recorded. Somewhere, I have pictures of these additional tags and will email you some samples when I can locate them - dont hold your breath though! Later, B.
Mines NZ assembled with the tag details mentioned here... http://www.fastlane.com....opic.asp?TOPIC_ID=22436
If you want I can post some pictures of them after the weekend
that would be great dave.
Warren
Thanks: 7 times Was thanked: 1 time(s) in 1 post(s)
Warren I sent Ben some info/numbers/pics including pics of ID plates about a month ago for an Aussie mate working in Sth Africa. its alime green (splice) colour HT front HG rear/ Vynil roof 308/ 4spd GTS Monaro not SS. If he has no longer got them drop me a line and Ill get them again 4U Cheers Nick Moran. |
"HOLDEN MONARO. OUT TO DRIVE YOU WILD!" |
PS Car will be coming back to OZ in nxt year or two and will live reasonably close to you. Ill keep u and Ben Posted. |
This might be an original NZ export, the tags and chassis stamp are in the photos to add to the register. http://www.trademe.co.nz...s/auction-272842332.htm
I just looked at a ht south African"...y is there no chassis number only a tag?
We use the chassis number for rego purposes, South Africa does not, henc no chassis number.
Warren
Warren, Just curious in knowing if all exports to NZ as well as other countries (including South Africa.)
Were different colour tail light lens and indicator lens fitted to all vehicles for export? Was this another identification factor or country specific?
The clear lenses are listed as export, but I do not think every territory got them.
Warren
NZ HTs Had the same lights as assy HTs . South Africa had different rules , like the reflectors on the nose cone on HQs . Mark. |
